Black pearl
  • Beaux
    • Dec 2015
    • 550
    Nice work, where do you get the 1/16 fiberglass plate? . thanks
    • flraptor07
      • Aug 2013
      • 2451
      Lookin' nice Larry, I got one of these from Pete. I just gotta get off my ass and get it done! lol When are you getting down here?
      • TRUCKPULL
        • 2971
        I got mine here
        Larry
        • TRUCKPULL
          • 2971
          Chris
          I am here. I got down on MON.
          Larry
          • Beaux
            • Dec 2015
            • 550
            thanks TRUCKPULL.
            • TRUCKPULL
              • 2971
              Larry, throw some glass on the inside of that nose piece. Then maybe some 2 part poly foam.
              I've seen and raced against Pete's a number of times. You'll love the way this runs Larry. Kinda reminds me of those mini Whips you were building the way it runs.
              Sorry Terry I missed this post;
              "Mini Whip" do you mean like this one:
              This hull is my LSH and N2 Sport.
              Video is N2- Sport
              I am debating what to do with the nose piece.
              Larry
              • Darin Jordan
                • 8335
                Larry... Update??
                Darin E. Jordan - Renton, WA
                • TRUCKPULL
                  • 2971
                  #23
                  Yes an update is due.
                  I got the paint done, Need to get some pictures.
                  Did a couple of test runs with different props last Sat. I am waiting for two new props (but Steven is out of stock right now)
                  I will get some pictures done and post them.
                  Larry
                  • Darin Jordan
                    • 8335
                    #24
                    Larry
                    Cool! What is the length and width of this hull??
                    • TRUCKPULL
                      • 2971
                      #25
                      Darin
                      The hull is 33 1/2" Long and 17" Wide
                      Larry
                      • T.S.Davis
                        • 6221
                        #26
                        Larry, do I see a Buass style sponson mod there? It's got that inner chamfer that I remember Brian experimenting with.
                        I finally got going on mine too. I've epoxied the tub to the frames. Tons of work left. I'm making some changes here and there too. Tiny stuff. Hope to race it at the cup.
                        Noisy person
                        • TRUCKPULL
                          • 2971
                          #27
                          Paint is done, nothing special.
                          Rattle can.
                          Rustoleum - Painters Touch
                          Ultra Cover 2X
                          3 coats each.
                          White Primer
                          Gloss White
                          Gloss Clear
                          Wet sanded with 1000 after Primer and Gloss White.
                          Still need to wet sand with 2000 and compound.
                          • TRUCKPULL
                            • 2971
                            #28
                            Yes you do see it, I run that on my Mini Wip and had it on my "P" Wip also.
                            Terry
                            I took your advice and put some foam in the nose.
                            I used 1/2" Pink that I used in the hull,
                            Glued 3 pieces together with 3M spray. Then carved and sanded it to fit all the way forward.
                            I used the 3M to stick it in.
                            Larry
                            • TRUCKPULL
                              • 2971
                              #29
                              I also got a bigger turn fin.
                              SS instead of the aluminum.
                              Larry
                              • detox
                                • Jun 2008
                                • 2318
                                #30
                                Raptor347 sponson aero mod was used on his SAW Whiplash to reduce lift and try to prevent blow over going 100mph.
