MHZ Lizard extreme with outboard
  • iop65
    • Mar 2013
    • 367
    now for something different
    started from a MHZ lizard extreme and should become a Bernico F2 extreme scale like model
    using the Thunder tiger outboard
    not aming for top speed but 40-50 km/h would be scale speed i guess
    working at the transom at the moment
  • shua
    • Apr 2015
    • 479
    Very Neat!! Looking forward to this one.
    • iop65
      • Mar 2013
      • 367
      more work done , transom getting shape
      • Beaux
        • Dec 2015
        • 550
        looking good! I am happy to see another outboard.Starting to feel like an only child.
        • Darin Jordan
          • 8335
          Love outboards. Should be a fun setup.
          Darin E. Jordan - Renton, WA
          • Beaux
            • Dec 2015
            • 550
            what do you think about aqua 36-56-2030 kb leg on a f1 hornet from hk?
              Nice work! What outboard is that? Tfl?
              • iop65
                • Mar 2013
                • 367
                no it's the thunder tiger unit , has an 1900kv 36 mm outrunner in it
                designed for use with a 40.6 mm prop and 4s
                but'm going to use it for with a beautifull 40mm 3blade cnc prop and only 3s , less rpm : easier on the flex
                have to say that i like the design : flex makes an angle of 45° and not 90° like most outboards do ( there is a gear inside and motor is tilted in an angle )
                sorry for my english : it's not my native language
                • iop65
                  • Mar 2013
                  • 367
                  i'm not an expert Beaux but if flex makes an angle of 90° : i'm not sure about the rpm's this can handle
                  • Beaux
                    • Dec 2015
                    • 550
                    thank you iop65, english looks ok to me.that cnc prop sure is pretty, I have some Two blades ,nice.
                    • Beaux
                      • Dec 2015
                      • 550
                      hey iop65, how's the boat coming?
                      • iop65
                        • Mar 2013
                        • 367
                        i'm a slow builder ( just needs to be finished in a few months)
                        work,wife, kids...too little time :-)
                        put in an extra 200gr/m² glasscloth in the hull
                        attached the motor because i'm working on the servomount : have to make that myself
                        as you can see : still needs some sanding , but's that an outside job and the wether is just to bad for that
                        • Beaux
                          • Dec 2015
                          • 550
                          Looks like a decent size motor on the out board. just got my f1 hornet together with that 3650 last night. the water is not frozen down here, we,ll be back in the 60,s this week so i will get to run maybe monday. good to hear from you good luck and stay warm.!
                          • iop65
                            • Mar 2013
                            • 367
                            servo mount in + applied some spray-putty:
                            • NativePaul
                              Greased Weasel
                              • 2761
                              Nice work, it is always good to see scratch builds or extensive modifications like these to show that despite the prevalence of prebuilt hulls and RTRs the skills aren't disappearing yet.
                              The younger Bertels from Bernico are keen FE racers in Europe as well as full size racers, I hope they see this as I'm sure they would get a kick out of it.
