8s1p by 2-4s in series.
MHZ Racemaster ~SINISTER~
I just picked up a DF sniper I'll be attempting my first inlay on that when I get around to building it.
Michigan Fast Electric SAW ClubComment
Got a little more work done today. i ordered an esc mount from MBP but needed a CF plate to be able to mount it, I don't have any laying around that's big enough so I decided to use a old CF battery tray. Looks like it will work wellI also got the rudder mounted and water inlet installed.
That's one intimidating looking monoComment
Had some unexpected time today to mess around with the mono. I got the steering linkage installed, I'm using a carbon fiber rod so I need to get the servo arm aligned perfectly. Also got the water outlet and antenna mount installed.. I got the hatch bolts installed tonight as well
Next weekend I'll be working on getting the servo mounted just gotta figure out how lolMichigan Fast Electric SAW ClubComment
Using a carbon fiber steering rod obviously cannot be bent, and I didn't want to put a shelf in and cover up easy access to the transom hardware. I found a servo arm from an airplane website that is perfect length so I can still use the mount I have, and get perfect alignment with the linkageI'll be getting the servo mounted permanently tonight.
Attached FilesMichigan Fast Electric SAW ClubComment
37" Fightercat Shocker powered by Neu 1530 on 10SComment
Nice job again. That stuffing tube mount is sick too the maiden is going to be a real experience.Comment
the maiden should be interesting, I'm worried there will be to much torque roll with how narrow this hull is. May have to shim the drive a little
Went to my buddy's to pick up the boat todaynow just need to reassemble her
Hi, I read at the start of the post that you would be getting your hardware done in black. I to go with that colour and it comes up great. The only thing I wanted to let you now was that with the trim tabs you have from speed master I could not get the stainless hinge pin out?.
I tried heating it, drilling it and hammering it. Not sure how they assemble them but it seems they must have a thread machined on one end and then the screw head must wind off during manufacturing.
Has anyone else tried to pull them appart successfully?.
Thanks Shane.Comment
