Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Warning: Trying to access array offset on value of type null in .../vb/bbcode/url.php on line 114 Next Best Flex??? - Offshore Electrics Forums
Next Best Flex???
  • rickwess
    • Apr 2013
    • 777
    Next Best Flex???
    With Hughey flex cables being as scarce as hens teeth, what's the next best that's available? Is a welded cable better than "Loctite" cable?
    Thanks.
  • iridebikes247
    • Dec 2011
    • 1449
    The flex Steve sells seems pretty good, I have bought his counter rotating sets and they've held up very well.
    The Hughey cables were great but I haven't been let down by the new stuff from OSE.
    • high-tech
      • Sep 2013
      • 331
      Ditto
      Keith Geusic #677 NAMBA District 19 Seaducer Gas MONO, Aquacraft Revolt Fe30, 30in Max Cat scratch Built
      • rickwess
        • Apr 2013
        • 777
        Good to know. Thanks.
        • dmitry100
          • Mar 2015
          • 1264
          iridebikes: Do you sand down the OSE stuff? Or is sanding not needed for this type of flex -- with larger diameter wire strands?
          It seems like I'm creating more contact area-- which would generate more resistance by sanding such a flex cable. Perhaps it would only somewhat benefit from just lightly polishing it?
          • longballlumber
            • 3132
            Tim has gone to great lengths to duplicate the Hughey shafts and has done a great job. I will be getting my flex cables from him now that the hughey shaft are no longer available.
            Later,
            Ball
            • dmitry100
              • Mar 2015
              • 1264
              Yes, but does he have them in reverse rotation ?
              But if you already have a stinger shaft -- can't you easily just flip a flex cable that is layed in either direction, or does it have to be specially made for reverse rotation? (for twin drives)
              • TRUCKPULL
                • 2971
                NO you can't just flip it end for end. It must be made specially for reverse rotation.
                Larry
                • dmitry100
                  • Mar 2015
                  • 1264
                  longballlumber: Do you know if he makes the reverse rotation flex?
                  • longballlumber
                    • 3132
                    There isn't any listed on the website, but he might make some. You will need to ask him.
                    • jfrancisco892
                      • Feb 2012
                      • 546
                      If he makes the shafts I can't imagine that would be an issue. Just solder the prop shaft to the other end. Or is there something I am overlooking?
                      • martin
                        • 2887
                        It dosnt matter which end you solder the stub you end up with the same rotation flex, you need a reverse wound flex.
                        • dmitry100
                          • Mar 2015
                          • 1264
                          What would you guys recommend in terms of teflon for 3/16 flex ? The Octura stuff I'm using seems kind of crappy...
                          • HOTWATER
                            • Nov 2008
                            • 2323
                            Later,
                            Ball
                            Yup...+1 ...Tim shafts are as close to Huey's as you will find. Great guy to buy from...very fast shipping!
                            -Kent
                            "Will race for cookies!"
                            IMPBA D12
                            My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
                            • HOTWATER
                              • Nov 2008
                              • 2323
                              I run with NO liner...no problems. Consider trying that...
                              -Kent
                              IMPBA D12
