Aeromarine 44" hydro
  • tth
    • Apr 2008
    • 1510
    #91
    Lizard is definately a green anole. They are all over here in south Louisiana. .......Great build also!
    • AntronX
      • Jul 2008
      • 333
      #92
      Thanks T! Here are the pictures:
      • NitroVal
        • Jun 2009
        • 423
        #93
        Where do you get those lipo cells from your earlier posts?
        The RTR Nightmare- Electric King of Shaves
        Now with 540s- 62mph
        New setup- Etti 150A's, Turnigy 2600s, 5S, X442s and a whole lot of cooling hoses
        • AntronX
          • Jul 2008
          • 333
          #94
          Also, check out my old and abused data logger. When one of my Turnigys burned, the logger's internal voltage regulator died as well. So it would only work from USB power. I soldered LM7805 to it, a 5 volt regulator IC across USB +5v power pins and fed it from 9 volt battery. This gave this Eagle Tree logger a new lease on life.
          • AntronX
            • Jul 2008
            • 333
            #95
            From THE BEST LiPo battery vendor in the world, Pat at www.rclipos.com
            • Ub Hauled
              • Aug 2007
              • 3031
              #96
              Anton, are you going to sharpen that prop of yours?
              • AntronX
                • Jul 2008
                • 333
                #97
                Should I ? It runs fine. Maybe you mean when will I polish it to a mirror shine?
                • Ub Hauled
                  • Aug 2007
                  • 3031
                  #98
                  it runs easier with a sharpened and balanced prop... perhaps even detongued...
                  • AntronX
                    • Jul 2008
                    • 333
                    #99
                    I definitely balance my props before running them. It is sharpened, but not razor sharp. I tried detongueing before and all it produced was less speed.
                    • AntronX
                      • Jul 2008
                      • 333
                      #100
                      Ran it today at full throttle continuously. Caps went up to 120F, not bad at all, but that was full throttle run. Will check how hot they get with 30 - 70% throttle run. Batteries were 137F by the time i got to measure them with IR temp gauge. They probably were 140 - 150F internally. That's not good at all, because amp draw was 90A average - a far cry from advertised 150A continuous. I will have to come up with lightweight water cooling plates for them. If i manage to knock that temp. down to 120 - 130F that would be great. Run time was 3 minutes 24 seconds before low voltage cutoff started to pull the throttle back, but i was still able to easily bring the boat back slowly.
                      • AntronX
                        • Jul 2008
                        • 333
                        #101
                        Ran boat part throttle, caps temperature peaked at 122F. Not much different from full throttle, which is great. Ran again with temp. sensor under battery heat shrink, reading peaked at 151F
                        BTW, who can tell me how many laps I ran looking at my graph below?
                        • NitroVal
                          • Jun 2009
                          • 423
                          #102
                          What lake do you run at? I wanna come watch the fireworks.... :p j/k
                          • AntronX
                            • Jul 2008
                            • 333
                            #103
                            No, there won't be any more of those. I run at this Lake.
                            • AntronX
                              • Jul 2008
                              • 333
                              #104
                              New video shot today in HD. Will be online by midnight today eastern time.
                              • Ub Hauled
                                • Aug 2007
                                • 3031
                                #105
                                alriiiiiight!!!
                                Let us know...
