TT Outlaw Obl JR - Rebuilding
  • Giacomo De Rosa
    • Aug 2015
    • 6
    Hi everyone , i'm going to share with you my first tt outlaw obl jr rebuilding project
    removing the old motor mount
    3674 goliton 2250 kv (up to 6s 90A) and carbon fiber motor mount
    Stock motor compared to 3674
    new prop shaft , flex shaft and strut. Yes i know , this strut is for cat but I had already had this at home , can I use it or i should buy a deep-v strut ?
  • capnswanny
    • Feb 2012
    • 817
    Looks nice and clean! I say run the strut, it's a fiberglass boat... if you want to change it it's very easy.
    Do a search for flooded tubes on OSE, it will help you take advantage of that strut adjustability!
    Nice work!
    Corey
    This is NOT a toy?!?
    • iop65
      • Mar 2013
      • 367
      this is an abs boat , not fiberglass
      hope you didn't use epoxy to get that motormount in :epoxy -abs :doens't make a very good bond
      wouldn't use that strut ; prop needs to be about 10% hull lenght behind the transom ,you can't do that with this strut so boat will run very wet
      had one for the kids , did some mayor rebuilding on it like you are doing but used a solid 4mm axle
      mine had a hooked hull and could not get it to run like i wanted ,but after i solved that it ran great
      • Tamelesstgr
        • Jun 2014
        • 1516
        I had good experience with BSI epoxy Mid-Cure on my abs ProBoat Shockwave 26 hull. USed it for laying fiberglass strips on the transom and throughout the hull. Heavy scuffing was required, but all season it has held up.
        NEVER SATISFIED RACING
        Fine Design 32 V-Hull 4082+6s
        • Giacomo De Rosa
          • Aug 2015
          • 6
          yes I used epoxy to stick the motor mount..
          I checked the lenght of my strut and it is as long as the stock one!
          • iop65
            • Mar 2013
            • 367
            stock boat : about 40 km/h?
            if you want it to go faster and not running very wet : prop needs to be further behind the transom
            l
              • 8012
              stock boat : about 40 km/h? if you want it to go faster and not running very wet : prop needs to be further behind the transom
              The strut the OP is using has vertical adjustment. He can loosen up the boat plenty just by lowering the strut - does the same thing as a longer stinger does. His boat will be fine with the strut he wants to use.
              As you gain experience with different hulls you will learn that there is usually more than one way to accomplish most things.
              • iop65
                • Mar 2013
                • 367
                using this strut he's got to be spot on or use a wet well to have that vertical adjustment
                • Giacomo De Rosa
                  • Aug 2015
                  • 6
                  Prop shaft and strut mounted
                  • Giacomo De Rosa
                    • Aug 2015
                    • 6
                    waiting for a 60mm watercooling jacket
                    • Giacomo De Rosa
                      • Aug 2015
                      • 6
                      Finished!
                      Watercooling jacket
                      • SweetAccord
                        Speed Passion
                        • Oct 2007
                        • 1302
                        You should use a solid one piece servo horn on the servo, that one is kinda flimsy. I have seen and have had those pop out. All else looks good.
                        • Giacomo De Rosa
                          • Aug 2015
                          • 6
                          Hey guys, here some news!
                          I removed the waterproof Box, I installed a new rudder (Longer arm) and a "home made" servo mount
                          some pics
                          A short video https://www.youtube.com/watch?v=9Kw8ZO1ApxE , the boat was running at 3/4 of full throttle due to the waves
