DF pirate 35" first build
Yeh you're right about plenty of work left! Though I do have plenty of time on my hands this weekend, hoping to have everything mounted on the transom tomorrow.
So is prop sharpening/balancing pretty straight forward? I've only purchased a couple props for my mg, and I bought them s&b. I'd like to try and do it myself though.Comment
You need a balancer, files, sandpaper and respirator. It can be tricky to do well depending on your ability
Sent from my iPhone using TapatalkThere's a hole at the center of earth where the rest of the world sinks but i stand still...Comment
Ok well I feel confident about it, being an electrician I feel I can do most anything, since well, kinda have to sometimes.
Sent from my iPhone using TapatalkComment
Yeh watched a tutorial.... No problem... Think I found something else to spend money on lol
Make sure you think about the dust you create. You don't want to breathe it in. I use water or oil while filing or sanding. Then clean the mess up after and dispose of the waste. Also think about the dust in your clothes. A regular dust mask probably isn't good enough. I use a $20 3m dual element respirator.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Ok, I haven't drilled good to know! Thank you HeathComment
Stuff showed up today! Things are happening again woot! Got the stinger and trim tabs mounted....
This tp motor is beastly! Motor to the back or front? I liked the way lucks came out with the motor to the back personally, and he said he had no issues with leaks...
Oh hell yeah dude!
Motor looks good rite about there man... Leaves room in front for the esc
Yeh buddy! Thanks bro! How far off center should the rudder be mounted? I'll just refer back to your thread see how it looks and go from there. Your battery trays, really just used the silicone? Is it mixed with resin or anything? I don't want anything to move, also I remember you saying your servo came lose, what caused that? Thanks luck youda manComment
Yes sir.
Quick!! Before someone snags it
http://forums.offshoreelectrics.com/...ad.php?t=52124
I just mounted the rudder where it fit, and far enough away from the stinger so when I turn the rudder the prop was still clear of it.Yeh buddy! Thanks bro! How far off center should the rudder be mounted? I'll just refer back to your thread see how it looks and go from there. Your battery trays, really just used the silicone? Is it mixed with resin or anything? I don't want anything to move, also I remember you saying your servo came lose, what caused that? Thanks luck youda man
On the trays, yes just silicone. It actually allows movement which is good. If the trays are too stiff they're prone to break loose. I have a tube of it from Keith bradley I'll be happy to send you. It sounds crazy and I couldn't wrap my head around it at first, but it works awesome.
The servo I had originally used cheap glue.
After I re glued with west systems it was fine.
Lmk if you want the silicone bro, no charge.
