ToysPort Jolly Catamaran Build (Single Drive)
  • Loki
    • Jul 2008
    • 39
    Whelp here I go all. I wanted to start a post with my new boat build. I’ll list out all the parts I’ve bought so far and general crap that I didn’t already have. This is my first build and a lot of you have been helping me with general advice and tips to help the build process go along well. I’m about as happy as a puppy with two peckers and having such a good group of people to help out just makes this a wonderful experience all together!
    If you see anything that I’m either missing, need to be aware of, or if you have any general hints/tips, please feel free to throw them my way (I am after all a NEWB)!
    Total Parts List:
    Castle Creations Hydra High Voltage 180
    NEU 1521 1Y Motor
    Neu 1521 Motor Aluminum Water Jacket
    Hitec HS-5645MG Digital High Torque Metal Gear BB Servo
    Futaba 3PM 3-Channel 2.4GHz Transmitter/Receiver Only
    2 x - FlightPower LiPo 22.2V 5000mAh 25C EVO25 6S Balance
    Receiver Battery
    OSE 5.5mm Gold Plated Bullet Connectors
    5mm Thrust Bearing
    Bru Line Antenna Mount & Tube
    Shrink Tubing 5/8" Wide - Clear
    6mm Red 10 Gauge Wire
    6mm Black 10 Gauge Wire
    Large 1/8"ID Silicon Tubing
    DuraTrax Socket Head Machine Screw 4mm L
    2 x - Bru Line Radio Box Tape 1"x60yds
    3m 1" Wide Velcro
    3m 2" Wide Velcro
    Props So Far:
    Octura m645 Sharpened & Balanced
    Octura x447 Sharpened & Balanced
    Octura x438 Sharpened & Balanced
    Graupner K Series 48mm
    Graupner K Series 45mm
    Graupner K Series 42mm
    Misc Gear:
    Corrosion X 6 Ounce Aerosol
    Rubberize-It Grip Dip Coating
    3m Dp270 Clear Epoxy
    Novak Solder
    Castle Bec
    First some HULL Pictures:
  • Loki
    • Jul 2008
    • 39
    Here's more of the inside and the equipment on the table:
    • Loki
      • Jul 2008
      • 39
      Ok here's the rest of the table of parts:
      • Loki
        • Jul 2008
        • 39
        Next I lightly oil the 'O' rings on the Water Jacket and slip it on the NEU Motor.
        Second I opened the receiver and coat the guts with 3m Dp270 Clear Epoxy. I didn't cover the 'button' on the receiver, but all else is water tight now.
        I also sealed the servo and added a little more marine grease to it as well. I went ahead and mounted it to the hull and started placing the gear inside to verify placement was good.
        * Side note: I really wish you could just order this stuff already sealed and ready to go (Waterproof) vs. having to do it on my own, but I guess it's good to look it over now.
        • Loki
          • Jul 2008
          • 39
          Next I played with the ESC. Hooking up the water cooling and placing it in the hull (talk about some serious water cooling). I still need to do some soldering work with the ESC in general and once I get the entire boat ready and the CG correct I'll shorten the wires and do a general clean up.
          One question if I could: The wires on the left (while facing the esc) are battery wires, the ones on the right are for the motor, so I assume that I’ll have to solder both sets together and attach it to the motor?
          I also have to tweak with the motor mount since it’s not 100% ready for a NEU motor. I’ll need to do some minor drilling, grease the drive shaft all up and then start with the hooking up of all the equipment.
          Please check over it all and please catch any possible issues I may be making or things I might want to think about. I’ll be tweaking with it either tonight or tomorrow after work.
          Thanks again all!
          Oh yeah! Once I get done with her, she's all good to go and happy with the whole setup I'll need to find someone to do some Air Brush work to her. Ya it'll sucks taking parts off again, but can't have her just white and without color!
          • Ub Hauled
            • Aug 2007
            • 3031
            Loki, on the cooling of the ESC I'd cut back the wrapping of the Hydra that is overlapping the tubes so you can push the silicone hoses further in a bit. Under pressure they may pop off the ESC and then disaster may strike if they are just barely in (like you have them).
            Cut the wrapping as far as you can w/o exposing the solders/boards and push the hoses in as far as you can ...
            My "2 cent".
            • Loki
              • Jul 2008
              • 39
              Ub Hauled – Thanks MATE! Yup I’ll do that tonight when I get home. I was honestly wondering why the plastic came out so far but wasn’t sure if it was ok to do a little cutting.
              I wish I could dump this thing in the rubber coating or the Epoxy to water proof it, but I have a feeling it has to breathe to stay cool.
              • Ub Hauled
                • Aug 2007
                • 3031
                Here in the US we have something called "Silicone Conformal Coating" (by MG Chemicals / spray version), that's what CC uses to waterproof their Hydras... if you are not sure about your water proofness just apply some more of that... I have to warn you, it has a very strong odor.
                • C.Smock
                  • Aug 2007
                  • 213
                  Looks Good!
                  Looks great Jim! Thats a 10-4 on you motor leads....
                  Also IMO it wouldnt hurt to rig up u rear motor mount/support.
                  That 1521 is a long motor. I would want the tail weight of the motor supported so it has no way of flexing.
                  My $.02.
                  good job on your first build!
                  67+ MPH N2 MONO
                  www.atlantamodelboaters.com
                  TEAM FLIGHTPOWER
                  • Quicksilver
                    • Jun 2007
                    • 211
                    that boat is so f'in hot!
                    someday.......someday
                    BOATS CAN FLY AND SHOULD!
                    • Doby
                      KANADA RULES!
                      • 7277
                      I use the same controller in my 1/8th hydro on 10S and it is rarely even warm to the touch, I got rid of the clear plastic coating and covered it in 30 Min epoxy (done in stages over 2 days) and it works great with no problems with moisture at all. The biggest headache is figuring out how to use Castles software,,but thats a different story.
                      Grand River Marine Modellers
                      • Ub Hauled
                        • Aug 2007
                        • 3031
                        Dobi, good to hear someone had the balls to drop one in epoxy...
                        I personally will never do that, I'd rather let it breath a bit more and if need be, I'd go as far as wrapping it in Kapton tape. Epoxy is too permanent for my taste.
                        • hkusp45
                          • Jun 2007
                          • 299
                          My jolly is so dry inside I have water proofed anything! Im using the trngy 100 12s speed contol fan cooled and it works great on my 1521 1.5D!! Ask UB, this thing flies!!
                          NAMBA #581
                          Q mono NAMBA record holder
                          'REMEMBER SOME PEOPLE ARE ALIVE SIMPLY BECAUSE IT IS ILLEGAL TO SHOOT THEM'
                          • Ub Hauled
                            • Aug 2007
                            • 3031
                            yep!
                            it's funny how this hull does not like slow speeds...
                            • hkusp45
                              • Jun 2007
                              • 299
                              Yes it does need to get up on plane first but when it does!! Watch out!
                              NAMBA #581
