MHZ Lizard Extreme MGM LMT Build
  • depeche_mode
    • Jun 2012
    • 144
    Hi All complete know nothing guy here. Thank you please comment and tell me what you think
    Boat: MHZ Lizard Extreme (Kevlar?)
    Motor: LMT 1940/7
    ESC: MGM 28026-3
    Battery: TP 70c 6s 4400
    Servo: Need Help
    Collet : MBP
    Prop: They gave me 39mm but it only makes a fine mist like smoke and does not go very fast??/ HELP
    So Today I removed SSS 4082/2200 to install LMT 1940/7. However I did not order correct size motor. It is too short and too small in diameter to fit into rear support bracket.
    Have I made too big an error? If so can I sell this stuff? HELP Thank you All
    Ps if It can work What settings on the ESC
  • RayR
    @SiestaKey.calm
    • Jun 2007
    • 1518
    You will not need the rear support bracket for the 1940.
    As for the prop, I would start with an Octura x442.
    Servo: How much height is there between the mounting plate and the stuffing tube? I suspect you are going to have to use a half height servo.
    Best to ask MGM on the settings.
    • kevinpratt823
      • Aug 2012
      • 1361
      The Lehner site will give you an idea on timing for you, it is higher than typical motors. Being a 3 connection motor, it is a "D" wind, for Lehner I believe they recommended 10 or 15 degree.
      My private off road rc track
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1837
        LMT timing is 15 degrees, I would have used a 2240 or 2250 LMT for that hull, and even better as an 8s setup so something in the 1200-1300kv range. The 1940/7 is 2239kv under load so on 6s it's already some high RPM. There is a good chance you may be restricted to a very small prop if you run 6s. The MGM controller would have been a little more flexible if you got the 25035. Not saying what you're doing is wrong, but you have eliminated some options by using that setup.
        • depeche_mode
          • Jun 2012
          • 144
          @RayR Thank you. 50mm
          @KevinP Thank you. I found it you rock!!!
          @Nata2run Thank you. I will order 2250/8 and 25035 So I can run my helicopter packs as well??... 70c 6s 4400
          Thank everyone for their help.
          • RayR
            @SiestaKey.calm
            • Jun 2007
            • 1518
            I missed that you were running 6s. To much prop for kind of rpm, go smaller. That is a 4s motor.
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1837
              the 2250/8 is 1480kv do you plan to run on 6s or 8s? if 8s that's still some serious RPM but if 6s then its a good sport setup maybe in the 70's or so (with the right prop) if you run on 6s then no need for the ESC upgrade
              • depeche_mode
                • Jun 2012
                • 144
                @nata2run Thank you Maybe I will get a cheap motor as well
