I re-checked my COG, and the numbers would add up to me needing to adjust the stinger and trim tabs...
Boat is 520mm long
So my COG is way back on the boat, there's no other reason to my mind why it would have to be change... If anything, my understanding is that it needs to be moved forward, in an ideal world?
Cheers,
Martin
Edit: Make-A-Wake: didn't see your post suggesting to check COG, thanks for the input, really appreciated mate :) So the above numbers is very close to what I got when I started out with the rebuild, hence why I talked about the stinger/tabs... What do you reckon mate?
Boat is 520mm long
- No Battery 140mm COG from transom - 26.9%
- 2.2A 3S 130mm COG - 25%
- 2.65A 3S 125mm COG - 24%
- 2.65 4S 115mm COG - 22%
Cheers,
Martin
