I purchased this boat from an OSE member who created a custom rudder solution using a TFL drive meant for a 60" or larger boat. One of the first things I wanted to do was change the rudder back to the Keith Bradley Boats (KBB) type A rudder for 45" boats. As you can see in the pictures below, I ran into a problem and I'd appreciate some help on how to proceed.
Old setup: TFL rudder arm is 70mm back from hull. The actual rudder sits 45mm back from the hull
New: KBB rudder arm is 50mm back from the hull. The actual rudder sits 42mm back from the hull.
I am not sure about the best way to proceed. If I keep the current hydraulic arms, I will have to create another piece of billet that is 20 mm wider which will push the rudder back an additional 20mm...which would make it 65 mm from the rear of the hull. If I keep the rudder in the same location I will have to either modify the hydraulic arms and/or more likely I will have to remove them completely. The hydraulic arms on this boat, for reference, are 34 mm long from the center pivot point coming off the hull to the end of the black arm.
