Hardware suggesitons
  • G-UNIT
    • 949
    I need advice on strut length,motor choice and any other suggestions you might have on this boat, its about 27" bow to stern and about 10" port to starboard.
    as you can see its pretty flat, not much of a v hull.
  • G-UNIT
    • 949
    I'm not sure what you mean by a strike, and a turn fin up front? like a hydro?
    do you have any pics of what your suggesting?
    thanks for any help.
    it used to have a skeg out the bottom but I cut it off.
    • steinersamuel
      • Nov 2008
      • 405
      the skeg on the bottom you cut off is what he is talking about I believe. Because the bottom is so flat, the hull needs an opposing surface to give it "guidance" or directional control. without it, it would be like unbolting the turn fin on a hydro.
      If it were me, I would reinstall the skeg on the keel, somewhere around your CG. Use a short skegged strut with a shortish offset rudder as close to the transom as possible. speedmaster will have the strut you need.
      • steinersamuel
        • Nov 2008
        • 405
        Heres a good pic of the keel skeg
        • G-UNIT
          • 949
          Ok I see it, I plan to put turn fins and trim tabs on it, would this help the same way the skeg would or should I do both.
          I'll need to make a skeg as I don't have the one I cut off.
          • steinersamuel
            • Nov 2008
            • 405
            without the skeg up front there would be no need for turn fins in the rear. In its simplest form, that hull needs the front skeg, skegged strut, and rudder. I would run it at that point and see whats what.
            I try to think of it like a mono hulled sailboat with a center board. The center board serves two purposes, to prevent it from capsizing in strong winds, and to give the rudder an opposing surface. without it the boat simply would not turn, it would do more of a dog leg of sorts.
            • G-UNIT
              • 949
              Now I got it, so i'll make a skeg and reinstall it and start picking out the strut and rudder or should I say strudder.
              thank you very much,
              • G-UNIT
                • 949
                I'm thinking about putting two skegs on this boat one on eather side of the center line and at the cg which is 10.5 inches from the back of the boat, question is how long do you feel the skeggs should be? and also since there is so much room in there would this be a good choice to build a twin with two 2000kv motors, with two 85 escs. just a thought.
                • G-UNIT
                  • 949
                  Question.
                  When finding the cg do you do it with the strut and rudder installed and should the motor be installed @ the cg point.
                  also are strikes the ribs on the bottom of the boats?
                  thanks for any info.
                  • steinersamuel
                    • Nov 2008
                    • 405
                    CG should be found with the boat at a "ready to run"state, and measured from the transom forward.
                    All motors, batteries, mounts and hardware should be in there prospective locations.
                    With an electric setup, most CG corrections can be made with battery placement because they are the heaviest item in the boat. With gas boats, the engine and fuel tank placement are more critical because they are the heaviest objects in the boat, and they are not easily moved.
                    • G-UNIT
                      • 949
                      Ok so I don't install a motor a cg but just where I want inconjunction with my stuffing tube and adjust cg with the batterys.
                      I got a strudder, It seems small but it is for a .150 flex, as mentioned before are the strikes the, how can I say it, ok like the ribs on the bottom of the boat.
                      or should I install skegs in the bottom,two, one on eather side of the centerline near the transom if you know what I mean.
                      thanks again for your help on this.
                      • steinersamuel
                        • Nov 2008
                        • 405
                        I would do a single skeg down the keel, somewhere close to the cg.
                        Planing strakes are the ribs in the hull that run parallel with the keel. they are designed to help a deep vee get up out of the water. I would not use them on a flat bottom hull like this simply because it needs no help to get on top of the water.
                        • G-UNIT
                          • 949
                          Great, thats the answer I was looking for, but one last question for now anyway, How long or how deep do you feel the skeg should be? the one I cut off was at least 2.5-3 inches long, seems a bit large to me but then again it was a gasser.
                          thanks again.
                          • grsboats
                            • Jul 2012
                            • 972
                            Your boat has a flat botton like the Dumas kit so this link can be a help :http://www.dumasproducts.com/product...roducts_id=791 Gill
                            GO FAST AND TURN RIGHT !
                            www.grsboats.com.br
                            • grsboats
                              • Jul 2012
                              • 972
                              In the late 70's I built one of the SK daddle's boats from Dumas(the big .60) so if you get some plans you can see the original set up and hardware and make some upgrade.Hope this help Gill
                              www.grsboats.com.br
