Help with the seam on my CF HPR C-5009
  • KillerDave
    • 370
    Hi peoples...
    I am STILL working on my HPR and have put it back on my bench to get some paint on her but before I get that far, she needs a little bodywork...
    The seam (joint between the top and bottom of the hull needs working on to get it completely flush before painting plus, I need to get rid of the marks left but what I believe Hans Peter uses to push the hull out of the mold and I have a little damage to some edges that also need filling...
    You can see most of what I'm talking about here...
    And this is my design... sktched out on good old fashioned paper!
    I have a guy at work making up some airbrush masks for my and for smaller sponsors logos I will print out some transfers...
    Any advice on filling and/or paint would be great!
    HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
    • 7673
    Well, I have used glazing putty for my sponson blue printing and on the bottoms of monos for hooks as well as seams and other imperfections. It dries reasonably quick(hrs or overnight) and sands easily.
    • SirBudman32
      • Aug 2011
      • 625
      This is my Cheetah I just did this summer. As you can see I did the same thing, no joint seem all the way around. I used Dura Glass and finished with Icing. Leaves a mice and smooth finish. Don't use Bondo, it is power based and any water gets to it it will soak it up like a sponge.
      Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
        [ATTACH=CONFIG]123336[/ATTACH][ATTACH=CONFIG]123337[/ATTACH][ATTACH=CONFIG]123338[/ATTACH][ATTACH=CONFIG]123339[/ATTACH]
        When you have the boat painted, how does water get through the paint and the clear coat to soak in bondo? Just wondering.
        • SirBudman32
          • Aug 2011
          • 625
          Any kind of paint chip or scratch!
          • flraptor07
            • Aug 2013
            • 2451
            What is Bondo based? Power? Most Body Filler "Bondo is a brand" is Polyester based as in Polyester Resin. Dura glass is a good product for filling Fiberglass.
            • SirBudman32
              • Aug 2011
              • 625
              Bondo is talcum powder based.
              • flraptor07
                • Aug 2013
                • 2451
                OK I got ya, yes it has Talc in it but it's not Talc based. It's Polyester Resin based, just for the heck of it take some baby powder "it's mostly talc" put some water in it and see what happens. Unless you stir it real good it doesn't mix real well, it almost looks to repell water.
                • KillerDave
                  • 370
                  Glassing putty, Dura Glass, Icing??? I don't think I can get these products here in the UK...???
                  I have Gel-cote filler but whenever I've used it before, It's never really cured? I was thinking of using that and have been told I need to cover it to remove the air from its surface??? Not sure?
                  • Kaotic
                    • Jul 2014
                    • 447
                    You could use Marine RX made by West Marine. I bought mine off of Amazon or if you have a West Marine or boat supply store near you they tend to have it usually in stock.
                    Michigan Fast Electric SAW Club
                    Revolt - 76.9mph...Building a DF35- Project Mono
                    • flraptor07
                      • Aug 2013
                      • 2451
                      Glazing putty, Spot putty, Icing, Etc. is all the same product. Duraglass is something different, they also make a Light weight Body Filler that would work. I'm sure you can get this stuff in the UK, you just need to find a store that sells supplies for Body and Fender Shops they should have what you need.
                        I see....we'll I didn't take that into account....I don't scratch or chip my boats lmao! (Except for the one time I wrecked my geico!.....but that didn't matter at that point, it was tore up)
                        • KillerDave
                          • 370
                          What about this stuff?
                          • Fella1340
                            • May 2013
                            • 1035
                            West marine 410 microfiche fairing filler used with epoxy resin. A HPR deserves the best!
                            • KillerDave
                              • 370
                              Thanks for that... So this stuff is like microballons but finer??? I'll mix it with epoxy to make up a filler and use it like that???
