that would have to be a twin for a 72" boat.
New build a CRC Mystic 73" Catamaran
https://www.facebook.com/groups/EliteRCBoats/ -
Dual motors setup I'm just trying to figure out the best setup right I purchase the Hull but I don't have it yet.
I heard that the 72 hull will need really good electronics to move well so I'm feeling out and taking every input I can so I can make the right purchase. Thanks for your input.Comment
I would ask keith Bradley, he has built this exact hull. Like I said I was looking at building it, but the power needed, even if you went with 2028s, the batteries required is a small fortune. It would be fun as an electric but unless you have A couple grand to throw on lehners and mgm controllers, that's what's needed to really make it move properly. I'd go with gas, that's how I'm going to build mine.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
https://www.facebook.com/groups/EliteRCBoats/Comment
The battery cost makes me cringe. If you check out the German forums the guys are making up these massive carbon fiber battery cages. There very cool looking, all the batteries wired together with a printer port plug for balance charging. I wish I new where to get the big bulkhead fitting for the main battery supply. They really like them big over there.Comment
Finally Getting some parts but I still need more parts, Any advice on a Servo for this monster?
I still need motor mounts and ESC mounts.
IMG_0288.jpgIMG_0385.jpgIMG_0479.jpgIMG_0480.jpgIMG_0481.jpgComment
You dont need 12s for a twin setup, as noted already 10s is sufficient. If you want to go 12s the 950kv is too high, look in the 700 range.NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
Glad to see parts coming in. What's your budget for this build w/o lipos? The thought of having a 6 feet boat is awesome but I'm sure the cost is overwhelming, not to mention transporting that beast. Definitely a different league once you get past the 48" mark.Comment
What size and kv motors did you end up with, cant tell in the photo........NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
10s2p.......? You can go 10s3p with acceptable tempsNEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:http://forums.offshoreelectrics.com/...est!&highlight=
as for the servo question, id look at doing 2 high torque servos or even 1/4 scale. youre gonna need a lot of torque to turn that beast. look forward to seeing how this comes out....im still itching to get one.HPR 135 redemption, HPR C5009, modded zelos 36, 32 boats and counting.
