Thanks! I'm getting excited just waiting for parts. The esc came in last friday but i've been pondering using bullet connectors instead of soldering the motor directly to it since i kinda want to upgrade to a castle 2200kv later. I have ordered everything but the Batteries!! getting so close. Will definitely be running 4s in parallel so that i can have great runtime and keep it in the water so it doesnt cavitate at 20 mph... lol But this wasnt meant to be a speed demon, just to run some rapids and have fun making it! I think i may go EC5 on battery connectors so that i can get a parallel adapter from a friend who has some which would save waiting time :D
Traxxas Spartan Jet Boat build
Alrighty, got nearly everything but a water pickup (one i got wasnt big enough) and more water cooling hose. Just picked up a couple of EcoPower 4s 4100mah 35c lipos to run in parallel! Waiting on parts now! Will be getting the other things from friends or lhs. Getting closer now!!Rc cars and rc boats all day!
Traxxas 4tec 3.3, Serpent s411 eryx 2.0, Traxxas Spartan Jet boat, (soon to come: Latrax Alias)Comment
Man, y'all are behind!
Got a Leopard motor jacket
Got a savox sw0231mg and some water cooling tubing
Got 6.5mm Castle connectors and some 3m carbon fiber wrap
Made it look nicer!
Got motor mount and ec5 connectors but the motor clamp is 40mm when i needed 36mm
Where i'm at:
I just need a little bit more cooling tubing and a 36mm motor clamp. I got a couple of 4s lipo's on the way and i will be getting parallel connector from a friend.Rc cars and rc boats all day!
Getting close now.
Love what you are doing.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Lol thanks guys! Yea i should get it up and running by the 25th since i'll be going camping by the river then! I got nearly everything done but soldering and positioning the motor correctly... Trying to position something at 5* and trying to mod the mount without a dremel is fairly difficult...Rc cars and rc boats all day!
Man that looks great the only thing I see is your steering link might be a issue because of the sharp bends, maybe too much flex. Run it and see what happens, it might work fine.Comment
haven't read every post yet and i hate to be that guy but you should have considered twin jets, the spartan is a big boat for that little drive, nice as it is. hope it turns out to be a fun runner.Comment
Lol yea twin jets wouldve been nice if they'd fit with the batteries not being all the way forward but i dont think they will. That and i will most likely cavitate at alot less. I also heard that at 20,000 rpm, a jetsprint boat was able to reach 30mph so with mine being heavier and sitting deeper, it may reach around 35 mph with 28,000 rpm. I just gotta get the trim right.
Yea I'm ok with the sharp bends of the steering linkage for. I tested it and it did fine. My issue is the steering arm can be fragile if too much force is applied (like running and weeds catch it....) If it does break, i will cut down some CF and epoxy that on to steer.Rc cars and rc boats all day!
Did the soldering on the esc, motor and batteries! But i just realized i damaged my receiver wire so i need a new receivers for my spare tqi.
410289792.jpgRc cars and rc boats all day!
