Twisted Sisters Build
  • RayR
    @SiestaKey.calm
    • Jun 2007
    • 1518
    Started a build chronicle in my Gallery.
    Decided to call her Twisted Sisters because of the well chronicled slight twist in the hull as well as powering her with counter rotating twins.
    Hull - Head of the River 32" Cat (28" running surface)
    Power - Twin 6L Fieago's on 2S2P
    More pics to come shortly.
    If you click Title + it will put them in order
  • highndry
    • Nov 2007
    • 664
    Nice. We have a cat class that puppy can run in. Keep us posted
    Boats don't win races, drivers do.
    • RayR
      @SiestaKey.calm
      • Jun 2007
      • 1518
      Updates in the Gallery.
      • Eyekandyboats
        • 1921
        LOL ray!!!!
        i am doing the SAME THING!!!
        but hacker 6L's instead.
        and hydra 120's
        EYEKANDYGRAPHICS
        www.rclipos.com
        • RayR
          @SiestaKey.calm
          • Jun 2007
          • 1518
          • RayR
            @SiestaKey.calm
            • Jun 2007
            • 1518
            New Pic Added
            • hammertime
              • 513
              damn u beat me to it i wanted to do this when i found that hull on ebay.... where it says appiration is that a sticker and can it be remover... either way i jealous of this build right now
              60% of the time... it works every time!
              • RayR
                @SiestaKey.calm
                • Jun 2007
                • 1518
                hammertime,
                Yes and no on the decal. Yes, it's a decal, no you can't take it off since the entire hull is clearcoated. Guess you could exacto around it and remove it.
                Ray
                • ED66677
                  • 1300
                  Ray,
                  I know the e bay dealer but was wondering if the hull is worth the money? I mean is the quality good?
                  I was thinking of getting one and use 2 700SC with 4S lipo?
                  Emmanuel
                  • RayR
                    @SiestaKey.calm
                    • Jun 2007
                    • 1518
                    Actually, the quality is good. The mold is not. The sponson botton on the Starboard side is a little twisted. Not a race boat, but for a nice fun pond cat, should be fine.
                    You will have to work at fittng twin 700SC's in there. It's tight.
                    Ray
                    • ED66677
                      • 1300
                      are you going to use some 540 or 380 6L?
                      Emmanuel
                      • showstoppercat
                        • May 2007
                        • 95
                        I would like to use (2) 9xl's or 2300kv Ammo's - with (2) Xpower 100a esc -
                        Question:
                        What motor mounts & MHZ air scoops have u used???
                        Also i think I will go with those ETTI stringers found them on AsTec website but I would like to use OSE SV27 Flex cables do you think they will fit???
                        • RayR
                          @SiestaKey.calm
                          • Jun 2007
                          • 1518
                          From the bottom up.
                          The ETTI Stingers are great, BUT, they are 4mm drive units. They are delivered with flex cables and teflon tubing. As well, 3/16th's props will need to be shimmed. In the U.S . you will have a problem with replacement parts.
                          The Scoops I used are MHZ #4 small.
                          Most importantly, what props do you intend to use? There is a BIG difference between a 1800 and 2300 KV motor. I do not believe your 100 amp controllers leave enough room for error.
                          All the best,
                          Ray
                          • ozzie-crawl
                            • Sep 2008
                            • 2865
                            i have the same boat running a single 7xl on 4s goes rather well and iam in the process of doing a twin but the hull i have for that is unpainted. going to run 8l 380s on 3s. were are you going to place your batteries. scott
                            • showstoppercat
                              • May 2007
                              • 95
                              Rudder needed
                              Where can i get a rudder with a triangle mounting bracket like the ones recommended for the CT03 04 or HPR06 from swissmodelpowerboats to suit a 32" Cat
                              anyone please help
