36" wood frame single screw cat build, advise welcomed!
  • msedsp
    • Jul 2014
    • 4
    like the title states I'm building a 36" wood frame catamaran. I found these plans online:
    Customcatsheet2-Model.pdf I took the plans to staples and they scaled them up to 36". Also I bought some 1/8" Baltic birch ply from Woodcraft. I plan on a single motor and 2 x 2S lipos I think I've settled on this motor mount:
    ose-80230-B_medium.jpg Dependent on which motor I choose. It seems as if the main choice is a UL-1 motor which it seems as if there's only one choice the aquacraft 6 pole, am I right? or do you guys have any better suggestions? also I need help finding the right drive gear (inline strut and rudder, flex cable size, cooling parts, etc) this is my first wood frame, especially this big, I've built some small wood over foam models before so the build itself hopefully should be easy for me.
  • msedsp
    • Jul 2014
    • 4
    Plans printed out, Templates cut out for main stringers, now on to cutting some parts!
