Time for me to build my first saw boat
    • 8749
    After building my cheetah, a GEICO and a Daytona I figured I'd try to build something fast. I chose a carbon fiber rivercat. I've been wanting one of these neat little hulls and on an impulse buy I bought one the other day. I'll be getting started on it in the best few days when I get my hardware in. Its going to be heavily reinforced from the inside. I'll do a carbon inlay along with running carbon fiber down the seams as far as I can reach. I'm going to reinforce the transom heavily with carbon and flooding with high quality epoxy. My motor is a castle 2200kv 1515 with a fighter cat 240amp ESC running on 6s for speed passes and 4s for cruising the lake. I haven't decided the servo yet. I'm open to any help, opinions or parts you guys may have I might need. Right now I need a servo and a mr200 receiver.
    Parts ordered
    2 part marine floatation foam
    Flex shaft(s)
    Couple props
    Strut and rudder assembly (pending)
    Windshield decal
    Parts I have
    Cf rivercat hull
    2200kv castle 1515
    240a fighter cat ESC
    Hobby wing ubec
    Water jacket
    Stuffing tube
    Hatch locks (might be too small
    Drive dog and bullet nuts
    Parts to make
    Cf battery trays
    Cf trays to mount the esc, servo and receiver
    Cf covers for everything
    Here's my hull
    • 8749
    Tonight I'm going to try and vacuum bag some battery trays. I'll post pics if anyone is interested.
    • iridebikes247
      • Dec 2011
      • 1499
      nice, you're building some nice looking boats man keep it up! The inlay will help a lot, usually on a thin hull I'll do one layer of cf on the tunnel and keep it nice and light, same with ride pads, then two layers for the sidewalls.
      I wouldn't try to do 2 layers of cf at once with epoxy, I always have difficulty gauging how much epoxy is absorbed and if the base layer is adequately soaked or too soaked. Have heard some hit or miss things about the FC controller so proceed with caution, especially considering this is an expensive hull and will have a lot of cf work done.
        • 8749
        Thanks man! I'm going to run a strip of cf tape down the seam then do my inlay.
        The fc ESC....I've been warned about using the Bec in it. I was told if I use the Bec it WILL fail. So that why I've got a seperate Bec for it. I have to remove one of the wires in the receiver pigtail to do it. If it don't work out I'll just get a swordfish.
          • 8749
          Vacuum bagging some more battery trays. This time using all carbon instead of a balsa core like I have been.
          • mekzoid
            • Nov 2011
            • 114
            Hey mate use some coremat along the seems and transom then cover in cf cloth. Is much cheaper then cf. I bought 10 meters for $50, It just needs to be covered in resin front and back, Most brands change colour when they have had enough resin, Some dont though.
              • 8749
              Thanks. I already have a few feet of carbon fiber tape for the seams and several square yards of cf so no biggie. I'm not trying to hold back anything on this build.
              • mekzoid
                • Nov 2011
                • 114
                Okay cause I was going to say I obviously have a fair bit so I could always send you some mate. Really gonna watch this build as per your cheetah :)
                  • 8749
                  Thanks man! I'll be getting Started on it this weekend doing my inlays and stuff. I can't wait either!
                    • 8749
                    I had a little time to fool with it this evening. I also got some goodies in the mail today. Couple flex shafts. Couple more props. 2 part foam. Reamer to try and convert my strut to ball bearing and a centering tool for marking perfectly centered holes. I went to Walmart and picked up some lime green pool noodles and a bigger tool box too. I sanded the interior of the boat getting ready for inlay and epoxy reinforcement . I also made some braces to go under the rails where the canopy mounts to. I felt it was too flimsy in that area where my hatch locks will be so I made some L shaped braces to help it out. Here's the braces
                    And then epoxying them in. Lol I ran our of clamps hahaha
                    • mekzoid
                      • Nov 2011
                      • 114
                      Bloody hell you always do some finesse stuff haha. Looks good man.
                        • 8749
                        Thanks. I'm going to be doing a few little things here an there to make it very strong. I expect alot of blow overs until I get things right on it. I despise hatch tape. I've had it come off on a hard hit and the boat almost sank. I believe the hatch locks and foam seal is a better way of doing it off done right. I have my cheetah done this way and it gets no water in it sitting upside down quite a while. I've also read on here where people had thier hatch come off with tape g to and list their boat.
                          • 8749
                          Did the first pour on the sponson floor. My idea is to get it flat so I don't have to use battery trays. That also adds strength to the sponsons should I hit anything. Also adds a couple ounces of weight to the very bottom of the boat (my thought is more stability?) and the batteries will be lower. So all in all I only see positive results (in my mind anyway! Lol) in doing this. I'll post some pics of it later.
                            • 8749
                            Picked up 3 different 2 part epoxies from the hobby shop today. I'm using a quick cure to fill the inner parts of the sponsons so my batts will sit flat. My hardware for the boat came in today. Bout the only parts in waiting on is the motor mount, hatch locks and the hatch seal. I made my experimental ball bearing strut for it too. I used 6 ball bearings in it for extra support. Its smoooooth. The bearings I bought are rubber sealed by fast eddy. Ill let the start strut in my tool box incase I have an issue. My wire came in today too. I got tired of running out of hard to find 8ga silicon wire so I bought 20ft of it lol.
                              • 8749
                              Detailed the strut. I feel like the sharp cut in it the way it came wasn't high and low enough. So I fixed it.
