Tenschock Electra Big block
  • younglings
    • Jan 2014
    • 31
    Hi Guys !
    Sorry for my little english but i'm french :lowdown:
    I open this post to introduce my Electra 95 in progress . My goal is to break the barrier of 100mH with this boat …
    My setup is as follows:
    - 2 X leopard serie 4082 2200kv
    - 2 X Truginy Marine 180A
    - 2 X Turnigy nano-tech 4000mah 6S 45~90C Lipo Pack ;
    - 2 X Drives MHZ Mystic 1114
    Here are some pictures of the equipment already received :
    I already have a little progress in strengthening the hull and rudder assembly.
    Tomorrow I attack the stingers and I will make some nice photos !
    have a good night !
  • Doug Smock
    Moderator
    • 5272
    Welcome to OSE Yoann!
    MODEL BOAT RACER
    IMPBA President
    IMPBA 19887L CD
    NAMBA 1169
    • Alexgar
      • Aug 2009
      • 3534
      Watching
      • Mattwarner
        • Aug 2011
        • 487
        I personally wouldn't use those mounts in the sponsons as you won't be able to get to the outside fixings once they are epoxied in place
        • NativePaul
          Greased Weasel
          • 2761
          Out of curiosity, what is in the little black bottle with the long white lid on it from MHZ?
          I know what you mean Matt they are FAR from ideal, but if he sets the front plate to the correct angle with threadlock on the screws before fitting and uses short hex machine screws rather than allen screws one the rear clamp, then he may be able to get a slim open ended spanner down the sides and get them on and off that way, a right PITA, but probably possible (check it out before gluing in).
          Will the motors be watercooled? As it is a SAW build maybe not (or just the mounts which aren't very effective, if you were relying on just those I would treat them as if they were not cooled at all), if the motors are not getting jackets he can swap the mounts round so the screws for the rear clamps are accessible, set both front and rear to the correct angle/height, threadlock the screws before gluing in, and easily slide the motor in and out from the back.
          • xkos
            • 168
            I have the same boat with almost same setup (with tp 4050l 2350kv motors).
            Its a great hull but you need to reenforce it as good as you can. It's very important this point of your project.
            Here is my last test on 5s https://www.youtube.com/watch?v=PjNE...re=c4-overview
            and here is the building progress http://forums.offshoreelectrics.com/...hlight=electra
            Good Luck
            Tenshock Electra Twin
            Vortex Hydro 24'
            • younglings
              • Jan 2014
              • 31
              In the black bottle is a "loctite" 648 for paste the flex
              yes it is the motors be water-cooled
              • younglings
                • Jan 2014
                • 31
                Good Luck
                very nice boat my friend ! and thank for your tips !
                • younglings
                  • Jan 2014
                  • 31
                  WORK IN PROGRESS …
                  next step to strengthen the hull !!!
                  • younglings
                    • Jan 2014
                    • 31
                    work work work …
                    • younglings
                      • Jan 2014
                      • 31
                      :rocking: always work work work
                      • younglings
                        • Jan 2014
                        • 31
                        coming soon ...
                        • ray schrauwen
                          • 9471
                          Did you use leftover gel coat dust to colour your epoxy? NIce job!
                          Nortavlag Bulc
                          • younglings
                            • Jan 2014
                            • 31
                            Thanks dude !
                            No , I use a dye to color my epoxy based collages .it is not a dye to the resin, but it works very well
                            • iridebikes247
                              • Dec 2011
                              • 1449
                              nice job man. just wondering how is the hull layup, is it pretty stiff stock or are reinforcements necessary to run with confidence.
