M&L GP400 Next ? Help
  • HOTWATER
    • Nov 2008
    • 2323
    #46
    I was hoping to also go with 2-3S packs but Mike L. advised me to go with 2-6S packs because it would need the weight...
    "Will race for cookies!"
    IMPBA D12
    My Gallery: http://forums.offshoreelectrics.com/album.php?u=1738
    • olwarbirds
      Magic Smoke Wizard
      • Oct 2012
      • 1136
      #47
      Ok that answers my ? ... tks Kent...how big a mah packs were suggested ?
      • HOTWATER
        • Nov 2008
        • 2323
        #48
        Not sure what is suggested but I think Mike had pics of a couplof 6S 5000 packs sitting in the front of the tub...supposedly there is plenty of room for all kinds of pack configurations. I will be using Hyperion 5000 35C packs...
        IMPBA D12
        • olwarbirds
          Magic Smoke Wizard
          • Oct 2012
          • 1136
          #49
          Yes there is plenty of room, its cavernous. Very easy to get my gnarled mits in it....One of the things I was planning on doing to save adding any "dead weight" in a sponson that Ive read about other people having to do too their "Hydros" , is make my battery tray mount adjustable for side to side movement, to control sponson lift.
          Got my ESC on its way from Mike L. .... soon as I have rest of the components, the build will go quicker.....DJ
          PS woohoo charging lipos, running boats tomorrow 60+ degrees
          • 785boats
            Wet Track Racing
            • Nov 2008
            • 3169
            #50
            Olwarbirds.
            I don't get any left sponson lift in mine & I have everything central. Unless of course I try to turn hard left at full noise.
            The only thing with weight, here in Aussie land, is that we can only race with a 1P pack set up, so I have had to add extra weight at the very front of the tub. The first couple of test runs were very flighty before I added the weight.
            • HOTWATER
              • Nov 2008
              • 2323
              #51
              785....would you say the weight that you added weighs as much or close to another 6S Pack?
              Do you have any pics of the inside setup of your boat?
              Thanks,
              Kent
              IMPBA D12
              • olwarbirds
                Magic Smoke Wizard
                • Oct 2012
                • 1136
                #52
                Paul, tks brother..I was going to ask you about this, glad you filled us in....Kent, Paul built what I think is a very impressive boat.....DJ
                • HOTWATER
                  • Nov 2008
                  • 2323
                  #53
                  Nice! Is there a build thread on it...mainly would like to see what's under the hood...already have plans about what I'm gonna do...always nice to see another one...might stur up some creativity in my build...
                  IMPBA D12
                  • olwarbirds
                    Magic Smoke Wizard
                    • Oct 2012
                    • 1136
                    #54
                    Kent, heres one link but I know there is another actual build too with vids http://forums.offshoreelectrics.com/...400&highlight=
                    • olwarbirds
                      Magic Smoke Wizard
                      • Oct 2012
                      • 1136
                      #55
                      Here is Paul's vid.... https://www.youtube.com/watch?v=u3G3OhMDoOk
                      • 785boats
                        Wet Track Racing
                        • Nov 2008
                        • 3169
                        #56
                        HOTWATER
                        I only added about 300 grams of lead but it is across the tub at the very leading edge. Not as much as a 6s pack but it's further forward so it has more effect on the COG.
                        That video was a first test run, before I added the weight. As you could see, a bit flighty so I was being a bit careful.
                        Here's the build thread Olwarbirds was referring to. You might glean a couple of ideas for your build or you may not.
                        Cheers.
                        Paul.
                        • HOTWATER
                          • Nov 2008
                          • 2323
                          #57
                          Thanks DJ and Paul!
                          Paul...saw your build thread...boat looks excellent! Thanks for the tips on your weight placement. Looks my use of 2S and 4S packs may just be the ticket for my setup...we'll see ....
                          -Kent
                          IMPBA D12
                          • olwarbirds
                            Magic Smoke Wizard
                            • Oct 2012
                            • 1136
                            #58
                            Paul, tks...I knew you had a build thread, just could not remember where....Kent yw, your right Paul's GP turned out excellent. I had forgot about Paul adding nse weight. I've decided to go with 2 6S parallel 8000 mah. Hopefully that will be enough.....DJ
                            • jcald2000
                              • May 2008
                              • 774
                              #59
                              10.5 oz. that's pretty close!
                              • olwarbirds
                                Magic Smoke Wizard
                                • Oct 2012
                                • 1136
                                #60
                                10.5 oz. would be a Low MAH 6S a 5000mah 6S weighs around 25 oz on average..... DJ
