My next build, TFL Ariane 2 Carbon Fiber
  • Doby
    KANADA RULES!
    • 7280
    #46
    My Blade is easier to see....
    Grand River Marine Modellers
    • flraptor07
      • Aug 2013
      • 2451
      #47
      Cause it's BIGGER and it's WHITE!!
      • skeeler
        • Jul 2007
        • 198
        #48
        The boat looks good for the first time out. Keep us updated.
        Revolt 30, River Jet, Southampton Tug, Outcast 6S BLX, 8ight-E, Ten-SCBE, 22 2.0.
        '09 Miata.
        Ibanez basses and guitars. Mapex drums, Zildjian cymbals.
        • flraptor07
          • Aug 2013
          • 2451
          #49
          Thank you, will do.
          • skeeler
            • Jul 2007
            • 198
            #50
            What's the advantage of the fiberglass hatch over the carbon one?
            '09 Miata.
            • flraptor07
              • Aug 2013
              • 2451
              #51
              With the CF boat and hatch you can have radio interference if you don't have a external antenna. I played it safe and got the FG hatch and the Futaba receiver I have has two antennas one inside and one external so there's no way I'm going to have any interference problems!!
              • skeeler
                • Jul 2007
                • 198
                #52
                Thanks for the reply.
                '09 Miata.
                • skeeler
                  • Jul 2007
                  • 198
                  #53
                  Another question: What size flex cable fits this boat? Was it included by TFL?
                  '09 Miata.
                  • flraptor07
                    • Aug 2013
                    • 2451
                    #54
                    3/16 and yes it came with, it's not a welded it's a square drive but you can put a regular welded flex in with no modification.
                    • Varooom
                      • Nov 2013
                      • 96
                      #55
                      flraptor,
                      I am looking at ordering a Nue 1521 Y1, 1577kv with a 8mm shaft from OSE. Is the 8mm shaft a problem with the TFL hardware or can I make it work? What do you think of this motor?
                      My Arian 2 will ship later this week according to Monica.
                      Thank you,
                      Varooom
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #56
                        Originally posted by Varooom
                        flraptor,
                        Thank you,
                        Varooom
                        No that's not a problem, you just need to get a 8mm to 3/16 coupler . but why are you getting the 8mm? They make it in the regular 5mm. Also if you plan on running it in Q Mono you should get the 1527 1Y 1250kv or 1527 1.5D 1500kv I found this out after the fact and I've got a 1527 for my Q Hydro build and I'm going to try it in the Ariane. But it will still be plenty fast on the 1521.
                          • 8011
                          #57
                          I'd get the 8mm shaft. On the longer motors (1521 and longer) we found long ago that the 5mm shaft could whip at high rpm, damaging the windings and causing much vibration. There is no downside to the 8mm shaft, and 8mm to 3/16" couplers are not hard to find.
                          • Varooom
                            • Nov 2013
                            • 96
                            #58
                            Thanks guys,
                            Just ordered the Neu 1527 1.5Y, 1500kv with the 8mm shaft from OSE. If my beautiful wife finds out I will be dead meat.
                            • skeeler
                              • Jul 2007
                              • 198
                              #59
                              Thanks guys,
                              What prop are you going to run?
                              '09 Miata.
                              • skeeler
                                • Jul 2007
                                • 198
                                #60
                                What prop do you plan to run with the 1527 1250kv?
                                '09 Miata.
