my new carbon fiber cheetah!
Get rid of that prop it's a waste of time for you to test with it.
The difference from a carbon prop to a good S&B brass prop is night and day.
Or get CNC aluminum at minimum
Start with a 447/3 blade or a 450/2.
I think you'll be wanting a 450/3 it will spin any of these no problem.
Get 1 that's sharpened and balanced from OSE.OSE GIFTING ELF
HAPPY HOLIDAYS!!Comment
Get 1 that's sharpened and balanced from OSE.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
How is the strut for being square with the hull? You can check this by placing a 3/16 brass tube in place of the prop shaft so it sticks way out the stern. If it is out by a bit that will track the boat. By this token you can shim the strut to straighten the tracking. Make sense?
Here is a REAL GOOD reference page for starting out with a hull. Chek near the bottom of page for 'setting up'. I know it says mono but the rules apply.
Gues I should post the page. http://www.modelpowerboat.com/conten...ude&styleid=4wLast edited by srislash; 02-16-2014, 11:28 PM.Comment
Yes gap is what i was refering to, drivedog to strut. More.Comment
Scott is referring to the gap between the drive dog and strut.
Gues I should post the page. http://www.modelpowerboat.com/conten...ude&styleid=4w32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
Not necessarily wrong... just room for improvement.Comment
Two more days left. Finished up a couple props for this weekend and ordered a few cnc ones and an octura 3 blade. Nor sure if the Octura will be here in time but we shall see. I also bought a skeg style strut to try out. Cant wait!32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
I got my skeg strut in today. Its set farther back than the strut I have now. At first I was just throwing the towel in an not gonna fool with it. Then someone talked me into it. So I need my stuffing tube to be longer and my flex shaft to be longer. Well I have a longer flex but I didn't really want to solder an extension on because I thought it would look like poo. Then it hit me. My geico has this nifty little cone in the front of the strut. I grabbed it out my box. Close but not close enough. Guess it was time to get creative now. I ended up making one on my lathe. It added some length to it to help support the shaft and I cut two grooves for orings to seal it. First time I cut a taper on a manual lathe. It was pretty tricky.
Heres the setback difference
Here's the geico one
Here's the one I made
Sweet dude,
I was thinking the same thing, make your own! Its good to see people on here with fabrications skilz.
On props, with that big ass motor, you can push a lot of pitch. As i learned from Fluid, a 50 mm prop will prop-walk a lot with this hull, so the only way to go faster is more pitch.
know that TP USA sells CNC props with a 1.6 pitch. They do need balancing though, or at least the ones I have from them.
What props are you getting?Last edited by larryrose11; 02-21-2014, 08:36 AM.Cheetah, Super Rio, (Mod) Starship (Mod and sold),Comment
Sweet dude,
What props are you getting?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
