1/16th Miss Thriftway Build
  • JimClark
    • 5902
    Starting the Thriftway build by building a jig to keep everything straight and true. Using a frame kit from ML Boatworks. Will post pics as I progress.
    Sent from my SGH-T989 using Tapatalk 4
    Billy Graham
  • JimClark
    • 5902
    Here is a pic of the real boat back in the 50's
    Also a replica , recently built from the orig plans
    Billy Graham
    • monojeff
      Moderator
      • Nov 2010
      • 2547
      Nice Jim tagging along!
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • rightturnonly
        • Jan 2009
        • 143
        Always enjoy your builds Jim..good choice...
        JOHN A. GROSS
        MILLBROOK, AL
        Crickety Crack Racing Team
        • Darin Jordan
          • 8332
          Jim,
          Let me know when you get close... I may have a power system you might want to try in that... :) Might be a good "proof of concept" hull for my power system idea with PSFEMBC... :)
          Darin E. Jordan - Renton, WA
          • JimClark
            • 5902
            Going to try to do the decking out of Mahogany also.
            Jim
            Billy Graham
            • JimClark
              • 5902
              Ok Darin I will keep that in mind though this one may take me a while as I want to deck it in mahogany. But i may just deck it in balsa and glass it and then foux paint in the grain. But I have been eanting to do a real mahogany boat for a long time
              Billy Graham
              • JimClark
                • 5902
                Got the building Jig done today and I had to wet the frames as I left them out of the box and they warped on me. Going to let them dry out for a while with weight on it to keep them flat. Also ordered the rest of the wood I need for the build and some CA to tack it together.
                Billy Graham
                • JimClark
                  • 5902
                  Full build gallery will be here
                  Billy Graham
                  • JimClark
                    • 5902
                    Looking for recommendations for a motor on this. Going to run it on a single 2s lipo. Prefer a motor that Steve carries.
                    Jim
                    Billy Graham
                    • JimClark
                      • 5902
                      Looking at the Leopard 2845/4.5 D 3650KV for this build? any comments?
                      Not sure on the ESC
                      Also think I am going to use a .098 flex shaft.
                      Billy Graham
                      • high-tech
                        • Sep 2013
                        • 331
                        Something tells me this is going to be a really nice boat built by a true craftsman!!!
                        And yes that is a good choice for a powerplant, the only problem I see is packing enough amps or (C) in batts and ESC in there, there ain't much room to play with
                        Keith Geusic #677 NAMBA District 19 Seaducer Gas MONO, Aquacraft Revolt Fe30, 30in Max Cat scratch Built
                        • JimClark
                          • 5902
                          It worked fine in this boat as i am only using a single 2s pack and this boat has a taller crown to the deck than the bardabl did
                          Thanks for the compliment
                          Jim
                          Billy Graham
                          • Darin Jordan
                            • 8332
                            Jim... that is GORGEOUS!!
                            Say, let me dig around and see if I have a 10.5T ROAR style brushless motor here. Maybe we can use your boat as a "test bed" for our 2S class idea with the PSFEMBC, since you have it about ready to go...
                            • JimClark
                              • 5902
                              That is from about 4 years ago Darin no need to look The boat is owned by someone else.
                              Jim
                              Billy Graham
