Twin cat build
  • Alexgar
    • Aug 2009
    • 3534
    How much for you to make 2 of the mounts for me
    • Alexgar
      • Aug 2009
      • 3534
      Had to do a little grindingof the stingers to get them to seat up properly
      • flraptor07
        • Aug 2013
        • 2451
        I don't think these will work real well mounted like that second picture, I don't recomend this type of mounting! It's gonna be a fun little boat...
        • Alexgar
          • Aug 2009
          • 3534
          you mean my bow thrusters on my lynx submarine? Should work just fine
          • Alexgar
            • Aug 2009
            • 3534
            Drilled and mounted struts working on sourcing some motor mounts
            • Alexgar
              • Aug 2009
              • 3534
              Pics
              • flraptor07
                • Aug 2013
                • 2451
                Originally posted by Alexgar
                Pics
                That's much better!
                • Jesse J
                  scale FE racer
                  • Aug 2008
                  • 7116
                  #23
                  Hey buddy sorry I haven't called back, new role at work and such.
                  You will probably need some more headroom for those freaking car motors! You would be fine with half the kV... But then you like I'm screaming. What size props are you using?
                  Sent from my Nexus 7 using Tapatalk
                  "Look good doin' it"
                  See the fleet
                  • Alexgar
                    • Aug 2009
                    • 3534
                    #24
                    Probably going to start with some cnc 35mm normal and reverse any suggestions?
                    • Alexgar
                      • Aug 2009
                      • 3534
                      #25
                      or 30mm 3 blade in normal and reverse what do you think jess?
                      • Alexgar
                        • Aug 2009
                        • 3534
                        #26
                        Also voltage options are 2s LiFe 6.6v 2s Lipo 7.4 pr 1s Lipo 3.7 what are you thinking
                        • Jesse J
                          scale FE racer
                          • Aug 2008
                          • 7116
                          #27
                          Target for normal boats is generally 30k rpms. You have 5000 kV x 8v =40k rpms, but these are high amp rpms. Props sound reasonable. Wondering why you like such hot setups... With your stingers up where you have them, you may be limited to props in the 40mm just to get enough blade wet. Give it a go and see how temps do.
                          See the fleet
                          • Alexgar
                            • Aug 2009
                            • 3534
                            #28
                            Could do 1s per side but thought that wouldn't be hot enough
                            • Jesse J
                              scale FE racer
                              • Aug 2008
                              • 7116
                              #29
                              Probably not enough amps to the motors and could damage the batts, but depends on mah capacity
                              See the fleet
                              • Alexgar
                                • Aug 2009
                                • 3534
                                #30
                                Thinking 1s1p Lipo 50+ c rating, what do you think?
