hydraulic steering arms
  • bonewar
    • Jan 2008
    • 549
    ok ive seen these on a couple of cats now , can some please tell me where i can buy some ( fake hydraulic steering arms, rudder with water pick up )first pic is from wd200-modellbau.de , not sure how to purchase from these guys.2 lot of pics is of a few cats i found with them on
    SIMRAD MARITIMO TWIN 1512 NEU'S , M12 MARITIMO SINGLE 1527 NEU , SV27 1509 NEU , SV27 NITRO O.S. 18CV-R 3.0cc WATER COOLED RACE ENGINE.
  • ChaKane
    • May 2008
    • 131
    I'm not sure if they are just fake Hydraulic arms or actually perform a function whereby they reduce / limit any twisting / turning from the rudder on the servo arm through some sort of pneumatic action. That said I can't see any servo arm to control the rudder...
    • bonewar
      • Jan 2008
      • 549
      i think one of the arms works (push pull steering arm) and the other is for show. 0ne set up) ,but i have also seen both arms attached to servos, so both push and pull.
      • ED66677
        • 1300
        I read somewhere someone made a cable push-pull actuated rudder, both cable are running through each piston's body, through te transome and are attached to the servo horn.
        Emmanuel
        • ChaKane
          • May 2008
          • 131
          Sorry to hijack the topic here but just a quick question.
          In the second photograph shown by bonewar I see that the water feed to cool the motor and esc comes in, through the motor and then across the esc before exiting. I would have though, depending on the voltage and speed you were running it at that the motor would be hotter than the esc hence better to run it across the esc then the motor before exiting or am I totally incorrect here?
          • westbeach
            OSE Rocks!
            • 951
            In the first thread by Bonewar, the FAKE hydraulic rams shown in the 3rd picture is made by Hanspeter for the Hpr cats. The rams have a shaft that comes out of the hydraulic cyclinder and one end is attached to the rudder and the other has a cable that goes to the servo. They are of the pull/pull type. I have a set that is going on my Hpr115 Cat. Hope this helps.
            HPR115 x2 ,Dark Horse Shovel, Delta Force CyberStorm, Delta Force Sniper 23-RTR:
            • westbeach
              OSE Rocks!
              • 951
              Heres some pics....so you get the idea.
              • bonewar
                • Jan 2008
                • 549
                westbeach mate where did you buy these from.please
                • westbeach
                  OSE Rocks!
                  • 951
                  Edit
                  • Jeepers
                    • May 2007
                    • 1973
                    try this place if you want real working hydraulic rams for RC
                    We bring you REALITY AT MODEL SCALE trucking and construction equipment that real works by radio control. We do not sell you a model in a box and say goodbye. If you wish to buy a truck from Precision Model Distributors you will do the same things here as you do in a real truck dealership. You first need to determine a brand of truck, Peterbilt or Freightliner, what you want the truck to do; haul oil, haul dirt, or haul bulk freight. You will need to determine your wheelbase, your power requirements, transmission requirements, and drive axle ratios and level of reality. These are a few of the real details involved in our trucks and construction equipment. If it is a dump truck or a Caterpillar wheel loader when you talking hydraulics we mean real with real oil. Transmissions metal transmissions with ball bearings, and three gears that you shift on the go by radio control. Realistic engine sound and a full lighting system interior cab lights if you want them. How about a realistic tow truck if you get stuck in the mud? From a light duty tandem axle to an ultra heavy duty eight wheel drive unit. Just like a real truck we have many accessories to add sparkle to turn your work horse into a show horse. We even have 1:16 scale driver available, union and non union depending on the part of the country you are working in.
                    • lonewolf
                      • Jul 2007
                      • 658
                      A few pics of my "fake" rudder set up
                      Twin cat 9xl,... 29 titan 8xl,....37 in mono kb48 8xl.... 42 in twin elc cat project... 42 in gasser cat 260 modded zenoh''' planes and trucks....
                      • bonewar
                        • Jan 2008
                        • 549
                        update
                        well they have arrived, and all i can say is awesome! these are true pieces of art . if any of you guys would like to buy these here is the email address ,Hanspeter Rotschi
                        hprotschi@bluewin.ch, swissmodelpowerboatteam, spedtoy
                        you will have to email hanspeter, he does not speak English to well but he will reply to all your emails. thanks Hans for making me a very happy man. bonewar
                        • ace028
                          • Aug 2007
                          • 952
                          Does it have a seal on the shaft? or do you put grease on the cable where the teflon tube goes?
                          Twin power =
                          • ace028
                            • Aug 2007
                            • 952
                            In post #3 what are the circuit boards with the ribbon cables for?
                            Twin power =
                            • Ocean Racer
                              • Sep 2007
                              • 502
                              The circut board you are reffering to is a esc's and the ribon is to strape the batterys in.
                              Failure is the First step to SUCCESS
