P-Ltd Vision OPC Tunnel Build for Ken Haines
  • Darin Jordan
    • 8335
    It's been almost a year since Ken sent this Vision tunnel home with me to build up for him, and I'm FINALLY getting around to getting it done for him. Had a couple of weeks working on it now. Figured I'd post some pictures.
    Have the transom drilled/tapped for the lower unit. Ken gave it to me drilled up with pilot holes, so I just opened them up and tapped them for 8-32 screws.
    I spent some time putting a lip around the inside to brace the cowl. I am NOT a big fan of this cowl arrangment and would much prefer a radio box with a standard removable cowl, but it is what it is. Should save a few ounces of weight I imagine. Has to be taped on, however, so I provided some interior support by epoxying on some carbon strips to provide the backing...
    Custom fabbed up a servo mount, similiar to what I did for my Lynx. Trying to use as much composite and no wood for this one, so I use some carbon angle I made for the mounts, and made a mounting plate from G10. All of the stainless screws are directly tapped into the carbon, where I added doublers to increase the grip area. All secures nicely. Since this isn't something you take in and out and in an out, this arrangement holds up nicely.
    Rigging is a 4-40 sized Dubro pull-pull kit. I use 60lb sized stainless fishing swivels through the threaded 4-40 sized clevis pins (through the threaded shaft section) rather than loop the cable through, as this holds up better and also provides a break-away point should the system fail in a flip/crash. Just replace the swivel head and you are back and running, as opposed to snapping the cable. Did this on my Lynx and it has been working exactly as designed. Blew over several times while attempting to set the 2-Lap record at the Nats last summer and was able to get back up and running in just a few minutes each time.
    Made the transom plate at the back of the cowl using some carbon plate I laid up. Made a pattern using some tape and cutting it out with an Xacto knife. Cut and fitted the plate, and then set it in place with CA. Used a layer of Carbon fiber weave laid up on the inside of the cowl to secure this piece in place.
    Wire exit ports are made from black fiberglass/carbon tubing. Wire extensions for the motor wires are held in place with heat shrink and tie-wraps, and stay part of the boat. This lets you remove the motor or ESC without having to reseal the transom.
    Cable pass-troughs are sealed using a set of Pro Boat bellows from a BJ55. I ran them inside the boat, just to keep it cleaner looking, and CA'd them in place. Should provide a decent seal, especially after Ken has it painted/decaled up and puts some light grease in them.
    Also, as you can see in the third picture here, I had to fab some spacers to raise the steering arm up to clear the transom. No biggy... some thick-walled aluminum and longer screws did the trick...
    Now that the rigging is all set, I just need to glue in some water passthrough tubes for the ESC, and then install the radio and power system. Will hopefully have it ready for testing by Memorial Day weekend.
    Darin E. Jordan - Renton, WA
  • Darin Jordan
    • 8335
    Some more pics....
    • Ken Haines
      Racer
      • Jul 2007
      • 647
      Looking good....Michigan here we come !!
      TenShock Brushless / Pro Marine
      INSANE Boats / Rico Racing/ Castle Creations
      2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
      • monojeff
        Moderator
        • Nov 2010
        • 2562
        Darin always a pleasure to follow your builds.
        If you want or need a windshield for the boat let me know be happy to send 1 your way.
        OSE GIFTING ELF
        HAPPY HOLIDAYS!!
        • Darin Jordan
          • 8335
          Jeff... I might... I'll have to talk with Ken. I'm not going to do any of the "decorating"... he has something in mind for that. I'm going to get it working and hopefully close to dialed in, and then send it to him and he'll do the rest...
          Looking forward to seeing how this thing runs!
          • Darin Jordan
            • 8335
            Finished up the build portion of this project... Basically just had to fit everything once the epoxy dried on the additions.
            Boat weighs in at 5lbs 7oz RTR with 5000mAh Thunder Power 65C 4S1p pack. TONS of room for battery. You guys just go ahead and keep putting your steering servos at the back with those clunky solid rods... I'll keep mine up front, where it belongs, with an elegantly engineering pull-pull system, complete with breakaway swivels to help protect the cable. Ease of access and battery placement on this boat is a dream.
            Still not completely fond of the tape-down hatch setup, but in practice, it was very easy to seal up. Definitely makes for a more open access to the internals.
            • Darin Jordan
              • 8335
              A few more pics...
              Also, I forgot to mention that I used 2-part expanding foam (2lb density) in the nose, and I also poured a narrow strip of foam down the center of the removable cowl section.
              The foam in the nose was for floatation, obviously, but also to help solidify the nose. With the cowl being attached, if you hit a buoy or boat with the front of this, it's not going to breach and fill the insides with water.
              • Darin Jordan
                • 8335
                Here is a video that my buddy, Theron, was nice enough to film for me during the testing sessions after the Puget Sound Model Boat Club NAMBA District 8 race on Saturday. The "dialing in" is coming along nicely. Have a few more tweaks to do to her, but overall, she's about ready to ship. Watch out, East Coast... Ken is going to be a force to be reconned with in this class!!
                • Darin Jordan
                  • 8335
                  I couldn't resist... Was doing some final prep work and just had to throw a quick polish on the lower unit... Hopefully, that doesn't slow it down too much...
                  • Ken Haines
                    Racer
                    • Jul 2007
                    • 647
                    That lower unit looks like a real machine now.
                    Can't wait to race this boat.....Hmmmmm....maybe Michigan
                    Darin, Thanks again for your highest quality work.
                    • Darin Jordan
                      • 8335
                      And... I finished prepping the prop last night... It started life as a GrimRacer 42x55... Not QUITE the same now...
                      One more shakedown run and I'll be shipping this to Ken. And Yes... he will have it in time for Michigan!
                      • obrien
                        • Nov 2007
                        • 1264
                        Darin it looks like the boat came out great. You are using the same prop I am, but I am sure with some different tweaks.
