Very Mean Mean Machine
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    #31
    What prop? When I ran mine on 2200 Leo 4s2p on m445 I was getting between 48-50.
    • Basstronics
      • Jun 2008
      • 2345
      #32
      TP Power CNC 45mm X 1.4P
      I got an M445 also... hmmmm
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        #33
        If you got some 5s packs you'll hit 60
        • Mike Caruso
          • May 2012
          • 940
          #34
          Originally posted by Basstronics
          One of my many new boats...
          Plans for this boat:
          TFL Cat Hardware w/offset rudder
          40mm motor mount
          TP Power 4074 2100Kv
          180 Sea King
          4S2P battery
          Aluminum servo mount
          With his big brother:
          What is the big brothers hull name? Single motor speeds for both boats a good guess with high $ motor? Or does the bigger one need to be a twin?
          Thanks,
          Mike
          Do It Like You Mean It .....or Don't Bother
          • Heaving Earth
            Banned
            • Jun 2012
            • 1877
            #35
            The larger one looks like a fc cheetah. They can do single power
            • Chrisg81983
              • Jul 2011
              • 1556
              #36
              Good luck with maiden should work out well. I am glad you resolved the rudder bracket issue.
              • Mike Caruso
                • May 2012
                • 940
                #37
                Thanks
                • Bomber Z
                  • Oct 2012
                  • 24
                  #38
                  You can still put a little more bend in the tube and set your drive down more.
                  • Heaving Earth
                    Banned
                    • Jun 2012
                    • 1877
                    #39
                    Here's where mine is set if it helps ImageUploadedByTapatalk1376841321.185900.jpg
                    • Basstronics
                      • Jun 2008
                      • 2345
                      #40
                      Mine is set flat on a flat surface. She has a lot of rudder... Spin out turns... Pretty fast, probably low 50's.
                      The TP Power water jacket is going in the trash. Its junk. I need to reset the ESC. I thought I had it all setup but it had the break on. She thermaled or something out in the water. Couldnt tell. When it got back in to shore the motor was about 130...
                      • Bomber Z
                        • Oct 2012
                        • 24
                        #41
                        Does anyone know if the transom higher on the old M/M's then the newer one? Looking at the picture it looks thinner then mine.
                        • SirBudman32
                          • Aug 2011
                          • 625
                          #42
                          My rescue boat doing what it does best, rescuing Basstronics boat....
                          Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
                          • Basstronics
                            • Jun 2008
                            • 2345
                            #43
                            Theme music:
