bby carbon outrigger
  • RandyatBBY
    • Sep 2007
    • 3915
    well that foilSim program is interesting it did tell me a little hint, Now I need to work it more.
    Randy
    BBY Racing
    • ktmakias300
      • Dec 2011
      • 47
      go for it randy i believe in you
        • 9488
        Originally posted by RandyatBBY
        Let me get mine built then we will talk. One mold left to do.
        Randy, I talked with someone else today and now this may make 4 of us
        twin PSpec power could be a hoot!
        • Mike Caruso
          • May 2012
          • 940
          [ATTACH=CONFIG]94430[/ATTACH]
          Which version of FoilSim? It is just what I am looking for. I started with Beginner it is very cool.
          Thanks Mike
          Do It Like You Mean It .....or Don't Bother
          • RandyatBBY
            • Sep 2007
            • 3915
            Thanks Mike
            Randy
            BBY Racing
            • ktmakias300
              • Dec 2011
              • 47
              my friends i respect your big experience in boats but some things must be checked from some programs like that....this is going to make you think about some things that you maybe never have thought in the past.......keep going
              • ktmakias300
                • Dec 2011
                • 47
                here some pictures
                • ManuelW
                  • Oct 2010
                  • 756
                  #23
                  shape of the rigger looks awesome. But thrust me, you can almost completely forget the results of foilsim for our application. Its pretty precise for a free flow over and below the foil, but in our application we run these very close to the water surface and ground effect has a major influence which changes everything. If you use a simulation software where you can take that into consideration and adjust the heigth of the foil above the ground, then it makes sense!
                  regards,
                  Manuel
                  • ktmakias300
                    • Dec 2011
                    • 47
                    #24
                    i am totally agree with you manuel.and i have adjust the height of the foil above the ground and i think i am 70% correct to my results. i have a lot of research to do but i think i am going to have a good result....
                    • ktmakias300
                      • Dec 2011
                      • 47
                      #25
                      first test on the water with small propeles
                      • RandyatBBY
                        • Sep 2007
                        • 3915
                        #26
                        Water looked rough, but good start. Got any pictures of the boat set up?
                        Randy
                        BBY Racing
                        • ktmakias300
                          • Dec 2011
                          • 47
                          #27
                          thank you randy for everything ...here some pictures P4030151.JPGP4030147.JPG
                          • ktmakias300
                            • Dec 2011
                            • 47
                            #28
                            second run with my outrigger from randy!!!!
