Scott's ML GP335
  • Scott T
    • Oct 2007
    • 590
    #61
    Graphics are all done now. I'm pretty happy with it and I think it is a fitting tribute to Mark Webber in his final year of Formula 1.
    I'll probably switch out the 1518 for my 1521 straight up and make do with the props I have. Can't wait!
    Scott Tapsall
    Pine Rivers Model Powerboat Club - Facebook Page
    My Gallery
      • 9488
      #62
      Looks really good!
      great job!
      • Kris Flynn
        #2 Bench Racer
        • 229
        #63
        Hopefully you don't have his luck
        • 785boats
          Wet Track Racing
          • Nov 2008
          • 3169
          #64
          Simply stunning.
          • Scott T
            • Oct 2007
            • 590
            #65
            Webber has a habit of flipping cars, and I have a habit of flipping boats, so its a perfect match!
            Scott Tapsall
            My Gallery
            • Scott T
              • Oct 2007
              • 590
              #66
              So, I've run this boat 3 times now, with mixed results. But today's testing showed some real performance! There's been ESC and centre of gravity issues, so I swapped the YGE out for an ICE 240. Seemed much better. Setup today was -
              • Ice 240 ESC
              • Neu 1521/1.5D motor
              • Entropy 5800 4S1P battery
              • OSE 5014350 3 Blade Magnalium 7075 propeller (50mm 3 blade)
              Very happy with the performance. Even with a stiff breeze and some chop I was able to run the full course flat out There will be a video up in the next few days.
              The CG issue required some surgery... Running 4S1P meant I could only get the battery so far forward, but probably not as far as I needed. **Note, this should not be an issue with Mike's V2 kits** So the CG was 2-1/2" behind the sponsons. I cut the bottom out of the boat and added a well for the battery that allows me to get it about 3/4" further forward. I also added 60g of stick-on lead to the sponsons (30g per side). Now the CG is under 2" from the sponsons, much better! The mod is complete, I just need to paint the underside white when I get the chance (it is sealed with epoxy).
              Scott Tapsall
              My Gallery
              • ray schrauwen
                • 9472
                #67
                Cool, thanks for sharing. There is a V2 265 & 335 coming my way soon. Is that motor mount strong enough for a 1521 with no tail ring for support? I guess it has to be if you are running it that way. No flex I guess??
                Thanks.
                You only run 1P in your area??
                Nortavlag Bulc
                • Scott T
                  • Oct 2007
                  • 590
                  #68
                  Ray, the mount seems quite rigid, so I hadn't thought of adding any more support. I could add one of Steve's new clamps if I find it starts flexing - http://www.offshoreelectrics.com/pro...prod=ose-83005 My carbon fibre floor helps.
                  Yes, only 1P in our country. Well, actually our EA class is 4 cells, so you could run 2S2P or even 1S4P, but 4S1P is the obvious choice. Battery weight limit is 650g.
                  Cheers,
                  Scott Tapsall
                  My Gallery
                  • ray schrauwen
                    • 9472
                    #69
                    Scott, what do you think of me running a 335 with a TP 4092-2200kv (from fightercat) ? I've used it for some time in my P-mono but, I have a 1521-1.5D to put back into the new P-mono. I just run smaller props like a M445 or M545.
                    I'd be running 4S2P.
                    Nortavlag Bulc
                    • Scott T
                      • Oct 2007
                      • 590
                      #70
                      Ray, I think that motor would definitely be worth a try! It's a bigg-ish boat, so I wouldn't want to go less than a 45mm prop. But if it worked OK in a P mono, it should be good in the GP335.
                      Scott Tapsall
                      My Gallery
                      • ray schrauwen
                        • 9472
                        #71
                        Thx!
                        Nortavlag Bulc
                        • Fella1340
                          • May 2013
                          • 1035
                          #72
                          Beautiful boat, it looks great inside and out. The attention to detail really makes a difference. It makes me want to build one!
                          • Scott T
                            • Oct 2007
                            • 590
                            #73
                            Video is up, thanks Pete! Excuse the driving, I've been away from the game for a while and still sorting out the new ride. Serious potential there though!
                            Video title is wrong, it's definitely a ML GP335.
                            Scott Tapsall
                            My Gallery
                            • Fella1340
                              • May 2013
                              • 1035
                              #74
                              That's just plain cool.
                              • ray schrauwen
                                • 9472
                                #75
                                Sweet ride man. I'm jazzed!
                                Did anyone catch on to the sound in the background? The sound of a motorcycle race track. Sounds like a fair number of V-Twins out there like Duc's etc...
                                What prop and setup is that? 1521 1.5D and batts etc?? Oops sorry, just read it, thank you!
                                Nortavlag Bulc
