Bought the hull awhile back and now getting things together and starting the build. First thing I did was a small pour of Z poxy in the transom to get it level on the inside and then covered it with some carbon/kevlar.
Cheeath
Cheeath
Last edited by SirBudman32; 02-05-2013, 09:36 PM.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Tags: None -
Now getting the hardware on the back.
IMG_20130205_135431.jpgIMG_20130205_135405.jpgIMG_20130202_211147.jpgIMG_20130205_135354.jpgModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat). -
servo bracket mounted and linkage made.
IMG_20130204_114646.jpgIMG_20130204_114825.jpgIMG_20130204_152652.jpgIMG_20130204_152735.jpgIMG_20130204_152752.jpgModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
That servo aint going nowhere.42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
Bud,
Take a minute and check my posts on Keith Bradley's forum regarding cracks in my Cheetah. If I was to build another, I would deffinetly put an additional layer of carbon cloth or carbon / Kevlar down before you go any further. If you intend to run in the 50mph and above, the Cheetah won't last without it.
ChipComment
I have seen your write up on the crack and plan on putting some more cloth in it. Thanks for the heads up.Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
Got the motor/ esc mount made. Put everything in the hull to find the cg. Now knowing where the motor will set I bit the bullet and drilled hole for the stuffing tube.
IMG_20130228_162150.jpgIMG_20130301_191701.jpgIMG_20130301_191845.jpgIMG_20130301_191901.jpgIMG_20130301_191912.jpgModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
With the stuffing tube in it was time to glue down the motor mount battery and receiver tray. I used J.B. Weld to hold everything down. I then made some holder for the cooling lines out of carbon fiber to keep everything kinda neat and in place.
IMG_20130307_115437.jpgIMG_20130307_115306.jpgIMG_20130307_115251.jpgIMG_20130307_115357.jpgIMG_20130307_115420.jpgModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
I also Stole one of properchopper ideas for the rudder linkage pass thru. I used a piece of 3/8 stainless tube I had laying around, must say works pretty good.
Also got my flex cut and soldered up. Getting good at soldering the flex with my new iron.
IMG_20130305_172039.jpgIMG_20130305_172737.jpgModified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).Comment
I have zippy 6s 5000mah packs. They won't fit without hull modifications if running twins. If running a big single then ya they'll fit you just have to slide them in through the back, the "mti cat," inspired hull area.Comment
