Painting with a spray gun...first time..
  • Heaving Earth
    Banned
    • Jun 2012
    • 1877
    #61
    Originally posted by egneg
    Solvent based paint is easier to use and gives a much nicer finish than water based paint. Be careful with the polisher - the last thing you want to do is burn through the CC.
    I disagree. Water based are much easier to use.
    If you have trouble with it, it is because you aren't using it properly. Most old timers refuse to like it cause they're set in their ways.
    Electric, I am certified by ppg in solvent and waterborne systems if you have any questions.
    I would never go back to solvent
    • Heaving Earth
      Banned
      • Jun 2012
      • 1877
      #62
      Ppg enviro base is the best stuff btw. It's a true waterborne, where other companies are calling their stuff waterborne, by starting with enamel resin and adding all kinds of chemicals to make it thinable with water. Ppg starts with latex resin.
      You can always tell by the can the paint comes in. True waterborne comes in plastic container. False waterborne comes in metal.
      DuPont comes to mind when I think of fake waterborne. Terrible stuff
      • Heaving Earth
        Banned
        • Jun 2012
        • 1877
        #63
        One last thing about waterborne is this, most people who will say bad things about it have either not really sprayed much of it, or they've sprayed the really crappy stuff.
        I have sprayed thousands of cars with it and love it.
        It def will not smell like those solvents do. It is no voc
        • Heaving Earth
          Banned
          • Jun 2012
          • 1877
          #64
          heres a restoration i did, yes this is waterbourne basecoat. who can tell me this looks any better or worse than solvent? noone
          • egneg
            • 4670
            #65
            Maybe things have changed over the years. I tried some of them when they first came out including PPG's envirobase, auto air, etc and was not happy with the results. I have airbrushed with many water based paints on various surfaces but prefer the solvent based paint.
            IMPBA 20481S D-12
            • Heaving Earth
              Banned
              • Jun 2012
              • 1877
              #66
              im sure things have changed, but you really shouldnt be critisizing something you havent much experience using. youre gonna give people false perceptions of things....
              most people cant get past how the basecoat looks when they first put it on. they expect it to look like solvent does when you apply it, so they just keep spraying it trying to get the solvent look instead of just waiting for it to flash, then wonder why it isnt coming ouit right.
              • electric
                • May 2008
                • 1744
                #67
                Sounds like I have stumble onto a controversial topic. I like the idea of a low VOC paint and I am assuming the clean up is much easier as well. Might give it a try on my next boat.
                • Heaving Earth
                  Banned
                  • Jun 2012
                  • 1877
                  #68
                  Well, I am strongly opinionated based on the amount I have used the stuff. 4 years now 3-4 cars per day. That's ALOT of cars with the stuff.
                  The reality is, a good paint job is gonna look good no matter what you use. Hok is no better looking than a well done waterborne job. Visa versa, hok will look crappy if it's not done well. In the end application is the most important part and can determine how the job looks.
                  I will say that with a little practice waterborne is much easier, lower voc, easy cleanup. It just makes more sense.
                  • egneg
                    • 4670
                    #69
                    Best of luck to you ... I still say solvent based paints are better.
                    IMPBA 20481S D-12
                    • Clueless1
                      • May 2011
                      • 273
                      #70
                      Jim,
                      Very nicely done! Thanks to all for sharing...great information!
                      • Cooper
                        • Jan 2011
                        • 1141
                        #71
                        I have a question, if I prime and use a base coat of waterborne paint can I clear it with spraymax 2k clear coat?
                        • Heaving Earth
                          Banned
                          • Jun 2012
                          • 1877
                          #72
                          The only way to be sure is to test on a piece of scrap. Mixing paints can go wrong from time to time. Should be ok, but never know. Spraycan clears contain ALOT of reducers which can cause trouble
                          • Cooper
                            • Jan 2011
                            • 1141
                            #73
                            Would it be a good idea to let the base completely dry say a day or two before clearing?
                            • Heaving Earth
                              Banned
                              • Jun 2012
                              • 1877
                              #74
                              Not necessarily. Paints have certain windows in which you should recoat. Generally I try to clear soon after the basecoat flashes off. You should read what the recommendations are on the paint
                              • Cooper
                                • Jan 2011
                                • 1141
                                #75
                                Have a hull to paint before long and this thread has given me lots of information. I will be asking on my build thread MADD CATT about What to use for primer, base ,and I have the clear. It's about a month before I tackle the paint. I've just used rattle cans before but would like to try something new. I like the waterborne paints for airbrushing. I can keep up with the cleaning and multiple color choices easier but I like the effects of the 2k clear coat I've used before. No pealing from hatch tape, no cracks, it just seems to hold up well for me. So again thanks guys. I just don't know it all yet,,,,,,,,lol,,
