Delta Force 26 Rebuild
Good one.
I love watching these little hulls get built. There's so many different setups. They can handle so many different power systems.See the danger. THEN DO IT ANYWAY!!!
http://forums.offshoreelectrics.com/...hp?albumid=320Comment
Good to see Mamba.
Before you take it for a run, can I offer a couple of suggestions?
It would be best if you cut those ties on the motor to ESC connectors & spread the connectors apart. They are creating a hot spot. I've seen heat shrink melt & bullets short out.
I would replace the bullet nut on the prop shaft with a Nylock nut. The bullet nut usually spins off & the prop ends up on the bottom of the lake unless you put some locktite on the thread.
Looking forward to the maiden. I hope all goes well.
Paul.See the danger. THEN DO IT ANYWAY!!!
to be honest i looked at allot and didnt find one i liked maybe someone will chime in and offer a suggestion but then again you could go this way http://www.offshoreelectrics.com/pro...t-oc6str-130daIm Only Responsible For What I Say Not For What You UnderstandComment
Holy smokes... will it run good with the prop that high up???
42" Osprey, 32" Pursuit, 26" Bling Rocket (rescue), Blizzard Rigger, JAE 21FE rigger, Hobby King rigger (RIP)Comment
