BBY PT SS45 build
  • RandyatBBY
    • Sep 2007
    • 3915
    BBY PT SS45 build
    I have been building a set of hardware for the PT SS45 Sport Hydro. It will be running oval with 6S and SAW's on 8S. This is the start with a `1/4 flex shaft, Dual bearing strut.
    Uploaded with ImageShack.us
    Randy
    BBY Racing
  • Namba328
    Factory Team Pilot SPP
    • Jul 2011
    • 1117
    why 1/4" flex? just curious.
    Tommy Levescy sponsored by: RCJuice.com, Rawspeed, Scorpion Precision Performance, TC Racing, Triton RC, Oxidean Marine and Cencal Hobbies.
    Current Namba 1mile record holder: Pltd sport hydro 1:19:72 P-sport hydro 1:14:31
    • RandyatBBY
      • Sep 2007
      • 3915
      On 8S it will be rock solid no breakage.
      Randy
      BBY Racing
      • LOVE6S
        • May 2012
        • 545
        Will a 1/4 flex rob a little power, compared to a 3/16?
        • RandyatBBY
          • Sep 2007
          • 3915
          Not really, we have 4,500 watts that is 6HP, He could get by on 6S but when you run 8S that is a lot of power and it is just safer. We have been twisting 3/16 on 8S and were real careful on setup.
          Randy
          BBY Racing
          • RandyatBBY
            • Sep 2007
            • 3915
            Motor mount and runners done ready to set up Blind nuts and mount.
            Randy
            BBY Racing
            • ray schrauwen
              • 9472
              Nice stuff Randy. Would this hardware suit a Whip Sport 40?
              Nortavlag Bulc
              • RandyatBBY
                • Sep 2007
                • 3915
                I do not see why not it is adjustable from 5 inch rails to 4 inch rails.
                Randy
                BBY Racing
                • RandyatBBY
                  • Sep 2007
                  • 3915
                  Motor installed with 10ton epoxy, Monday the stuffing tube.
                  Randy
                  BBY Racing
                  • Namba328
                    • Jul 2011
                    • 1117
                    is this for you randy or someone one else?
                    • Gary
                      • Jan 2009
                      • 1105
                      Looks good ! Make sure you stuff her full of floatation. A boat that big will fill up with water pretty good and go right down. I just had a nasty blowover on mine and destroyed the hull ripping the right sponson completly off but it still stayed above water for a while during its last retrieval. BLAHHH !!! No way she can be repaired this time. Good luck with your build !!
                      H&M 1/8 Miss Bud 73 mph
                      Chris Craft 16 mph
                      • phil t
                        • Feb 2010
                        • 169
                        Hi Randy, I will watch how you get this project together too, may want to do one for myself sometime. The 1/4 cable wont drag and is alot stronger than 3/16.
                        When you get ready to glue on the front canard be sure to cut out all the blue mark and the wing will fit in the slot, then square and level it up and mark the sponson side, cut that and use good epoxy to make a fillet.
                        Phil T
                        Phil Thomas
                        email [email protected]
                        http://www.philthomashydros.com
                        • ray schrauwen
                          • 9472
                          I meant the rudder & strut actually,
                          Nortavlag Bulc
                          • Gary
                            • Jan 2009
                            • 1105
                            I would like to see a final wieght number on ths project. Mine comes in at 13.4 lbs which is a little heavy for my likeing so im hopeing to remove at least 1 pound from the replacement hull. Please post your wieght when you get there, thanks,
                            Gary.
                            Chris Craft 16 mph
                            • RandyatBBY
                              • Sep 2007
                              • 3915
                              It is for a customer, Needing to pay my share of the bills in my family I have to do everything I can to make BBY profitable.
                              Phil T
                              Thanks for he info Phil all those little things help.
                              Gary, thanks I will keep all in mind.
                              Ray, I am using almost all standard stuff with a little mod on the strut arm to custom fit. It is not really a big deal I do it for all my boats. But yes it can work on any boat. if I know the strut adjustment like Phil puts it .(bottom of transom to top of table)
                              Randy
                              BBY Racing
