Rebuilding a wrecked Genisis
  • shrive81
    • May 2012
    • 53
    i have a new genesis hull i am bulding but i want to paint it befor the build starts. How did you paint yours and did you sand the whole thing first and what grit paper and what paint did you use? any advice or help would be great...
    thanks
    • MrUnlimited
      • Jan 2011
      • 94
      Shrive, the best method is too use wet sandpaper 600 grit and to spray windowcleaner unto the hull before sanding. This will give you a very smooth finish before painting. After that clean the entire hull with alcohol to degrease it. As for paint there are few options: best option is paint with a 2k paint like poly urethaan paint. But to use it you have to be an experienced painter. Second optionis to use enamel paint like Humbrol. You can use that in an airbrush or it is sold in aerosol can. Last option is use the normal automotive paints you'll find in the most hardware and carshops. This is acrylic paint so it is not that strong as first 2 paints. You can cover it with 2k poly urethane paint but some acryl paint are not that strong and 2k paint will burn in. So be carefull with your choice of brand. Here is my mhz138 which I painted with a high quality acrilic paint by Motip:
      My 1/8 hydroplane is painted with 2k paint by Sigma Coatings:
      • shrive81
        • May 2012
        • 53
        Ok so it's not just a rattle can paint job... I need to go buy a spray gun and hat not and learn how to use it hahaha man these rc boats are alot harder then I thought
        • MrUnlimited
          • Jan 2011
          • 94
          If you use enamel paint you can use a airbrush, but if you use compressed air from an aerosol make sure you put the can in a bucket with warm water and let it stay for 5-10 minutes. This helps to mix paint and air better for a better flow of the pistol.
          • HYDROJERRY
            • Jan 2010
            • 2503
            Not to upset anyone here but just throwing this out there, many of us use spray cans, most of all my boats are spray cans other then my store bault boat heres a pic of my latest all done with spray cans including clear coat so you can do a good job Shrive81 just probly not as good as the pro's..
            • Tbauer
              • Aug 2012
              • 261
              That's a very nice rattle can job!!!!!!
              • shrive81
                • May 2012
                • 53
                Hydrojerry you made my day I might consider airbrush but probay not and will end up doing spray can... What type of paint do you use on you boats (spray can)
                • HYDROJERRY
                  • Jan 2010
                  • 2503
                  I like the Rustolium paints, but i think ill use Tamiya or testers or almost whatever i can find for the colors as long as you use a good clear to seal it all,, thats just how i do mine and am sure many others do the same ..
