Hull: Tfl carbon Zonda 40 102cm twin brushless.
Hardware: Stock RTR
Motors: TP 4092 2100kv 4 pole
Escs: Turnigy Marine 180amp escs with bec. One bec disconnected.
Batteries: Turnigy Nanotech 7s 5000mah 65c x 2 (one for each motor/esc)
Props: Tfl aluminium 1.4pitch 48mm 2 blade
Fibre cowl so gps signals go through.
2.4 ghz ansmann radio.
Props counterrotating outwards.
Cg about 35% from rear.
First test new batterier: 151.6kmh
Second test 1 cycle on batteries: 155.8kmh /gps
The boat is stable it will go over 165kmh. we had to stop the top speed run because one driveshaft snapped.
The escs and everything seems too be cold too touch.
Had too remove LVC on esc because its a 6s esc.
Think amp draw is about 210-220amps. About 5500watts on each motor. 11000watts total+
Were from norway
Hardware: Stock RTR
Were from norway
