twin 90 size 18 lb rtr
neu 2230 outrigger
i built it. cant figure out how to post pics on the forum. interested in finding out if motor is too big for this boat. 18 lbs seem too heavy in my opinion. new to electric want opinions on batteries ( I'm using 2 6-s 5000 packs in series 40 c grimm 65x100 prop. fightercat 400 amp esc (barely fits in boat ) any little water gets in esc is toast . want to try swordfish 300 but wont be in stock for 3 weeksComment
I have one that I have run in my 41 cat and 43 inch Sport Hydro. I run it on 10S2P, prop it from 62mm to 67mm. speeds in the 67 to 80mph. If I was to build a rigger for it that would be a blast. I use a 40.160 Schultz ESC with no problems.Last edited by RandyatBBY; 07-08-2012, 01:14 PM.Comment
have you ever gotten the esc wet? why 10s instead of 12s? how many amps you pull with that controller ? hear any feedback on fightercat esc's I've run 94 mph with 65x100 grimm prop . whats the cost of that esc ? do they survive contact with water?Comment
sew run. It seams that all china junk (CJ) is over rated. We have been running the Swordfishes and not able to pull a lot of amps.
I get the Schultz's from
MY speeds are two way average passes.Comment
thanks for the info, have more questions if you dont mind. you are saying if you dont hit throttle after getting wet they survive with corrosion x ? do you submerge with shrink wrap on the esc? do you soak esc before you ever run it? how heavy is he hydro you run? if you have to send to germany how long is the wait and cost? do you think 12 cell is too much for my boat and the schultze 40.160? thanksComment
I have done that with cheap Turnigy ESC's with good results. I have been sacred to do it to any of my Schultz's, did you Conformal coat a Schultz?Comment
So are we going to see any pictures? It is not that hard if you can up load the pictures to your computer.Comment
