Has anyone made there own cowling for there hydro. I was wondering cause it just looks top heavy and I think a low intake would look good to.
Hydroplane cowling
Me too, I take a profile I like and then cut mIne out of construction foam then glass and epoxy. Done lots! See my avatar- that one is foam and glass."Look good doin' it"
See the fleetComment
I got my construction foam or insulation board at the local lumber yard. Granted that was in Montana, doubt they sell it in Houston.
I went to the yard and asked the guys if there were any damaged sheets and ended up walking out with a 3x4' chunk under my arm for free!"Look good doin' it"
Home Depot should have the foam depends on what epoxy you use if it works or not it has to be the slow curing type.
Sent from my MB611 using Tapatalk 2"Our society strives to avoid any possibility of offending anyone except God.
Billy GrahamComment
You want Styrofoam, a trademarked name product. When I lived in Alaska I could get the 2" thick Styrofoam at any building store, but in more temperate climates it is not available. All I can find locally is 1/2" thick 4'x8' sheets. I have glued these thin sheets together with epoxy to form thicker sheets. Keep the glue away from any edges you want to sand, it will make a scalloped surface.
A common question we hear all the time is, “What’s the difference between Expanded Polystyrene Foam and Styrofoam Brand Foam?” Some times, people are looking for expanded polystyrene foam products, but mistakenly refer to them as Styrofoam Brand Foam, even though the materials are completely different
I got a piece in the plumbing it ts used to put under the waterheater. I have also made one out of balsa. How big of hydro?
Billy GrahamComment
