Very excited to get this one going and can't say enough about the ML kits and how easy they go together and how clean and percise all the parts are. It takes a lot of guess work out of things and you know you will have a great product once everything is glued together and will give you a great base to start fine tuning. Mike has done his homework and really appreciate all the support he gives!
This boat will raced under Namba Rules as well as Classic Thunder.
Under Namba rules I will be running a 1500kv proboat motor.
Classic Thunder it is open motor for modern boats so I am planning to start out with a FighterCat 3740 2000kv Outrunner.
Here is some pics so far of progress just a few hours into things.
I am using a piece of granite bought for $10 as my building board to be sure everything is nice flat and level.
Thanks to Mike for the tips on how to go about doing this, the toy tabs make it even easier since they pretty much hold everything together and keep them in place.
Tacking things down with CA and accelerator then will go over everything with Epoxy once the framing is finished and checked to be sure it is all square and even.
This method goes very quickly and works quite well!
