TFL 56" Genesis twin
  • drwayne
    • May 2008
    • 2977
    Welcome to my nightmare !
    Was asked to finish for sale a TFL 56" Genesis partially assembled kit ( as from TFL )
    Comes with
    Hull, full Genesis decal set
    2 x 1/4 arneson type stingers
    1 x center mount cat rudder
    2 x engine mounts for 56xx motors
    2 x 8mm - 0.250 collets
    1 x 1/4 flex and stub drop down to 3/16 for prop Left rotation
    ditto, Right rotation
    2 x through hull pipes as pickups
    2 x Battery trays
    ESC/Rx tray
    Servo mount and steer cables
    I added
    2 x 5692/730
    2 x SF240HV
    2 x 5518/3LR
    2 x X465LR
    2 x dual underhull pickups
    2 x rudder cable brass outers/guides
    deck mounted esc charge button
    deck mounted battery disconnect loop ( Au rules )
    Out of the box it's an impressive hull with all but rudder blade attached .
    same as plain
    All parts sourced from, and project built for
    www.rcboatbitz.com.au
  • drwayne
    • May 2008
    • 2977
    All pre installed (a couple minor bits quite poorly) from the factory
    So I took everything out ... but the glued in engine mounts ... and returned them aligned ...
    • drwayne
      • May 2008
      • 2977
      Motor and , esc test mounted
      removed and realigned shaft
      • drwayne
        • May 2008
        • 2977
        SF240HV are superb ESC for 4-12S setups.
        Ive seen several know name brands fail under high startup load and/or extended draw.
        An external cap bank aids in buffering ripple voltage
        Ive made a pair here .. and attached direct to the ESC.
        6* 1000uF 63V rubycon .. this circuit equates 1500uF buffer
        Video further down thread, 2/3 through clip, shows WOT launch BIG props, , no issues....
        • drwayne
          • May 2008
          • 2977
          Stingers are as simple as you can get, but quite functional.
          1/4 teflon bushes support the 1/4 flex and stub, with the prop shaft end at 3/16 for dog, prop and nut
          3/16 stub length at 1.5" (38mm) length
          unthreaded so you need a grubscrew prop keeper.
          Shaft has flats for dog and prop keeper.
          • drwayne
            • May 2008
            • 2977
            Next was to stick it all back together
            The only real nasty thing 'out of the box' was the non waterproofing of the rubber steer cables.
            So I fitted 3/16 brass sleeves to run the servo cable guides through.. I epoxied the tube into back of hull, and used waterproofing bellows on tube as it approached the servo.
            The bracket below came with the hull. attached to the servo. So I attached them under cowl lip in same spot as pic, and ran brass tube through. moving brackets backwards 40mm gave space for bellows.
            Works a treat.
            Every bit of water protection helps !
            I pulled out the cheapass brass pickup tubes hot glued in the bum, and fitted a pair OSE dual underfhull pickups.
            These I merged each sides 2 inlets via a black T fitting from local garden centre into fed a single line to each Motor/ESC combination..
            Plenty of watet there now !
            Maiden saw 24+" spray from outlet !
            Flex shaft outers are expoxied CF to hull in the center of their length, and sit free from stingers .. The shaft is 0.5" from stingers, still within teflon.
            This allows the stinger up/down adjust +/- 4" without the need to bend the outer.
            Works a treat !
            • Xzessperated
              • Apr 2008
              • 3060
              Drooling over this one Doc
              Several boats in various stages of destruction
              • drwayne
                • May 2008
                • 2977
                The wiring for this is to Australian rules of max 12cells for top level 'EC'
                2 x 6S packs in series, mounted one a side in sponsons, shared as 12S to these medium draw mega big motors.
                2 x 6S50100C5800 handles these babies with ease. ( 12S50/100C11600mAh )
                And here's a few views of the dangerous end.
                • drwayne
                  • May 2008
                  • 2977
                  First few micro laps were maiden run.. returned to check for water ingress.
                  Returned dry, so taped again ... out it went on 5518/3 L&R props for some squirt action.
                  Spun a flex at collett at 1.36 ..
                  Drove to shore, and tightened all .. and out with X465 and full WOT runs.
                  OMG those flexes HOWLED.
                  Will recommend lower to owner
                  Failure last few seconds.. lost prop retainer on R, so steering biased.. prop gone to the deep 8(
                  Was it fun to drive ?
                  Sure !
                  regards
                  Wayne
                  Adelaide
                  Australia
                  • drwayne
                    • May 2008
                    • 2977
                    If floats, it drives well, and inside is a smoke free environment.
                    Time to send to the new owner,, and wait for the photos !
                    I changed out flexes to 1/4 with 1/4 stubs, with this power/prop it's foolish to expect oo much survivability.
                    - if not running 10+KWt 50V this would be unnecessary , Id stay with 1/4x3/16
                    2. after total of 4-5min fooling around here squirting and wot .. came back barely body tempt.
                    Wayne
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      Not bad doc, sure was fun on that day. Now let's get our own babies on the water
                      • drwayne
                        • May 2008
                        • 2977
                        1355 D.O.I. sent to CF inlay person today.
                        Cupla weeks during this chilly weather, before it returns.
                        B(
                        • Prop-a-Gator
                          • Feb 2012
                          • 163
                          Bring your toys over here Doc. It'll be about 90F today.
                          Do you have some pics of the battery disconnect loop? I've seen the Euro "Not-Aus", but I'm intrigued by this type. I understand the schematic, but I'd like to see what the installation involves. Thanks, T.
                          Disclaimer: I hereby accept the potential loss of motor, ESC, entire boat, or credit rating, and forfeit all expectations of success.
                          • drwayne
                            • May 2008
                            • 2977
                            here ya go !
                            plug between (not shown ) has 3" x 6AWG to 2x 8MM (big mother cooking) plugs from HC
                            • Remmie81
                              • Apr 2012
                              • 134
                              Nice build and that setup is haulin!!
