Hello ttc. :)
Thank you for reply. Yes i am running on 6S (two 3S in series) the first four minutes in the video, sorry for beeing unclear. Second half (at 3:55) i am trying with smaller 4S (two 2S in series). My cooling is working very well and temperature is around 35-40 degrees celsius. Since yesterday i have received many tips and ideas on what todo, first thing i am going to try is to shorten the water inlet tube so that only a few mm is below the hull. As it is now it is almost 1,5cm below the hull and this might be what is causing the nose dive as it is causing drag. Several "boaters" have pointed this out to me. Will fix this today then well see if that helps...
Unfortunally weather is not so good atm so it might take a few days before i can test my boat again. Also i need to figure out a way to avoid radio interference for my rescue boat since it loose contact when other 2.4GHz radios are On... I certainly dont want to go swimming again, like i did sunday, after all it is still May and not long ago it was ice on the lake...
My motor mount is stock, if you like you can check my "Optimizing Vanquish Video" where i show the inside of my Vanquish and how i got it (almost) water tight with silicone at the backside and at the transom. It still gets a few drops of water through the shaft, but it is not a biggie.
I almost lost my boat when i did the maiden run, had very much water inside and i got affraid that i might loose all hw in a short out with a loud POFF... Thankfully everything survived and i decided to make that video so that others could avoid making the same misstake as i did. Before every run i allways tape down my hatch incase i get nose dives or flips upside down.
Will keep you posted. :)
Have a nice day
Have a nice day
