MHZ Mystic 1380mm build
  • MrUnlimited
    • Jan 2011
    • 94
    #616
    Kent? 5800mph packs? Really?
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1837
      #617
      Yep super FAST LOL
      sorry 5800mah hehe (hate those auto spell whatever)
      • MrUnlimited
        • Jan 2011
        • 94
        #618
        Guys
        Does someone know if there are templates to drill the holes in the transom for the trimax drives in the hull? My drives arrived today.
        • Chrisg81983
          • Jul 2011
          • 1556
          #619
          Mr unlimited do u have a build thread I would like to follow it. The build sounds very interesting
          • Chrisg81983
            • Jul 2011
            • 1556
            #620
            Oh and kent where can I get the 5800 MPH packs sounds awesome and sorry for the double post
            • MrUnlimited
              • Jan 2011
              • 94
              #621
              www.v10power.ws is my blog
              • MrUnlimited
                • Jan 2011
                • 94
                #622
                Kent, how did you measure the holes for the drives?
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1837
                  #623
                  ...I used a template only made in paper printed on my printer
                  here is how http://forums.offshoreelectrics.com/...529#post420529
                  • MrUnlimited
                    • Jan 2011
                    • 94
                    #624
                    Guys,
                    What loctite do I use for glueing the flexshafts into the outdrive-axles: 603 or 638?
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1837
                      #625
                      I use 648, but I think the ones you mentioned will work as well
                      • MrUnlimited
                        • Jan 2011
                        • 94
                        #626
                        Thanks Kent, what is the length you have cut the flexshafts before glueïng?
                        • Alfa Spirit
                          • 2131
                          #627
                          Well Mr Unlimited what is your complete setup for your Mystic 1380mm ?
                          • MrUnlimited
                            • Jan 2011
                            • 94
                            #628
                            I bought these week 730KV Protues motors, I'll expect them to arrive next week. They will be powered by 10s lipo each. As for the probs I'll contact Andy Brown to modify some 2 blade prop for me and for esc I 'll go for the new Fliermodel 300A esc which can be programmed like the hobbywing esc (I run a Xerun 60A in my Tamiya Avante2011).
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1837
                              #629
                              730kv on 10s? That would not be fast, unless they turn to 1360 in wye mode?
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1837
                                #630
                                Didn't make any cuts before gluing. I just glued them in, and then cut to size after I measured the distance. I used a flex cable to measure. Feed it up till it hits the motor shaft, then apply some tape on the prop end and use that as a guide.
