Starting a New Project:
I am going to start building my 44" Avenger Pro 10S Cat... I got in the motor and speed control today!!! I will post more pictures tomarrow...
I am first going to try the NEU 2215/2Y (750kv) with Castle HV-180 esc and 10S lipo.... If I run into any issues, there is always the 2230 and HV-240....LOL
Setup::
1. Aeromarine 44" Avenger Pro (light electric lay-up)
2. Neu 2215/2Y (750kv)
3. Castle HV-180 esc
4. Top Secret Boats Hardware (strut w/skeg, rudder assembly, blue anodized water outlets/ thu-hull fittings and 1/4 scale servo mount)
5. Dasboata,,,1/4 flex shaft w/ step-down for 3/16 prop
6. OSE,,, 8mm-- .250 Coupler & 8mm thrust bearing
7. Hitec 755-MG servo
8. All 5.5mm connectors on Battery leads and esc power input wires,,, 6mm connectors on motor to esc
9. 4X 5S 5000mAh PolyRC lipos
10. X450, X452, X455, and X457 for testing... (All are OSE S&B props!)
Here are a couple pictures of the motor, esc and hull....
Setup::
So there will be many options for the cooling lines....
