Miss Vegas brushless Done!
  • OJ racer
    • Dec 2007
    • 170
    What should you use to reinforce your motor mounting spot?
    • miltonsafewaybuggy
      • Aug 2007
      • 15
      I used fiberglas cloth around the mount with some epoxy.
      • Jeepers
        • May 2007
        • 1973
        I did that also, still cracked the hull! I have now epoxied 1/4 plywood into those areas.
        • blakybob
          • 126
          Originally posted by SJFE
          FYI you will also blow the esc on 4s.
          Are you saying a hydra 120 will blow on 4s or the set up as a whloe (motor, batts, esc, and prop) will blow it? I read it a couple of times and thought I'd make sure what you intended to say there.
          Blake
          • Heath M
            • Mar 2008
            • 806
            i think he was referring to the original setup of the boat
            Heath
            Brisbane,QLD, Aussie
            • OJ racer
              • Dec 2007
              • 170
              I epoxied it straight to the hull before I saw the reccommendations against it, should I make some changes? I've had a couple fast runs without incident, but should I be worried?
              • Jeepers
                • May 2007
                • 1973
                It depends on how well your hull was built from the manufacture, some are real thick in that area, mine was not.
                just curious how fast were your runs?
                • Jeepers
                  • May 2007
                  • 1973
                  #23
                  Blake
                  I have used a 6XL before on 4s with a hydra 120 and a detounged x438 it survived a 1 mile heat race, but it was not in a boat the size of the Miss Vegas. I am not quit sure the hydro it was in was considered a boat after that, more like a plane waaaaaaaay to much motor,sure was fun though!
                  • Ub Hauled
                    • Aug 2007
                    • 3031
                    #24
                    This is my solution for this hull...
                    • Jeepers
                      • May 2007
                      • 1973
                      #25
                      ub how does it run? looks like a 1521.... 4s2p?
                      never had a chance to do mine on lipo!
                      • Ub Hauled
                        • Aug 2007
                        • 3031
                        #26
                        I have yet to get it wet.... this week it'll happen.
                        CG is maybe an inch behind the sponsons...
                        yes, it is a 1521/1D
                          • Aug 2007
                          • 15
                          #27
                          Finally hit the water a few times this month Prop selection was either an Octura x640 or x642,
                          I ran fast and cool in perhaps the 40+ mph range.
                          Played with the CG and got it to run with the sponsons barely touching the water.. hopefully I can get a video and some pictures up in the next few days
                          I also left the wing on the boat, although I know some guys are taking it off (OR BREAKING it off in a high speed tumble) Seems to be a non issue with it being on there.
