Sealing Lipos
  • miltonsafewaybuggy
    • Aug 2007
    • 15
    Sealing Lipos
    I hear some guys chatting about sealing up their Lipos. What are you guys doing to seal them up?
    Milton
  • Doby
    KANADA RULES!
    • 7280
    I use silicone with good results. Just make sure to get it all through the balancing wires and the mains.
    Grand River Marine Modellers
    • JimClark
      • 5907
      Best to use a neutral cure silicone also
      Billy Graham
        Best not to "seal" LiPos at all. No matter what the sealer is, the flexible wires will break the seal eventually. If the packs get even a little water inside, the terminals can corrode, causing the pack resistance to skyrocket. Result - puffed cells.
        The real solution is to seal the hull so no water can get to the cells. But a crash can open the hull. I've gotten packs wet and just cut and tore the shrink off to let them dry, the re-shrink. You can risk the chance that your unproven "seal" job held - but if you are wrong, there goes hundreds of dollars of packs ruined. Better safe than sorry.
