OK!! I have attached some pictures of the rudder setup. As always I spend a long time looking for the logic. I went down to the local sports fishing shop and got some 0.8mm stainless steel, "black plastic coated wire" (should be good for 120lbs) and some leader sleves to match, pulled it tight around a ball nipple and clamped together, used some heat shrink to cover the join. It may not look the best, but I sure cant pull it apart. Then just ran the wire into the servo through a piece of antenna tube. (watch out for water on this part!!)
Oh, had to drill the nipple out to 3mm to fit the MHZ rudder system. Also cut the MHZ supplied ball link down. (you'll see the dummy hydrolic ends sitting closer to the rudder)
MHZ Mystic C5000 1140 how I did rudder.jpgMHZ Mystic C5000 1140 Rudder done Close up.jpgMHZ Mystic C5000 1140 Rudder rear Close up.jpg
