Fightercat 950 Q build
  • tiqueman
    • Jul 2009
    • 5669
    Ben and I were in discussion a week or so ago and got on the topic of the new cats hes got out. He mentioned he had a 950 that needed completion and asked if Id perform the taks. "uhh, YEAH!" So it arrived Saturday. Its the only hull of the 950 lot that he got in Glecoat and not full carbon. Lay up is beautiful. It is a TFL hull measuring 37x11. The hull bottom is designed a lot like the PB Miss G, but the flat ride pads have a little angle on them, so its a combination of both. It arrived painted and with 99% of the hardware. The rudder mount and strut had already been mounted. He included one of his tricked out aluminum V-hull motor mounts that with some small modifications work well in the cat hull. And a bonus, its already got paint on it.
    I first assembled the mount just to see it in its correct form. (last pic) Then it came apart, removed the esc plate and set aside, ground off the esc extension mount pieces that are on the motor mount portion and flip the mount upside down. Stick it all back together and its a thing of beauty. (first pic but its all upside down to show the grinding)
    For now Ive just set it in a beed of epoxy layed down both sides of the tunnel and a beed along the contact point (bottom) of each mount support. I will reinforce it at a later point. It had to be placed w/in an inch or two front to back to clear the canopy. I put it in about the middle. I also did a little oblonging of the adjustment hole, mount support side, to raise the motor a bit in order to get a better angle down thru the hull. I also had to cut a hole in the rear mount support for the wires to pass thru. I plan on installing a rubber grommet to isolate the aluminum from the wires.
    Once that had tacked, I moved on to the stuffing tube. Ben supplied me w/ a tube and inner liner for use with a 3/16 flex he had also included. The nose of the strut would have had to been modified (drilled larger) for the tube to be inserted. Rather than doing that, I decided to go for my second build against using teflon liner. More and more folks seem to be going that route. So I ran to the hardware store and grabbed a stick of 1/4" brass, cut it to length and bent it up. After a few tweaks, I acheived a happy bend, added a stuffing support in the hull which I tacked in place and then taped up and epoxied the stuffing tube into position. Once cured, I did something I hadnt really done yet. I really like how under the Proboat cats, thay have extra resin where the stuffing tube leaves the hull, like a built in wedge. I taped up the sides, inside etc etc to make sure there would be no run out, and filled the "wedge" with resin. Once given a light touch with sand paper and a little shape to the back, and a quick shot of white paint, its going to look real nice.
    Thats about as far as I am as of now. Updates to soon follow as Im trying to have it done for this coming weekends Club meet. Ben asked if Id set it up for Q-offshore, which is perfect as Im currently working on my Q-offshore boat and wont have it back in the water by then. He also supplied me with a Tenshock CZ2760 4500w 8 pole 45 x 80mm motor at 1600KV to run 6S for the class. Should scream.
  • tiqueman
    • Jul 2009
    • 5669
    More pics
    • JackBlack26
      • May 2007
      • 905
      Sucks to be you :P
      • JPriami
        N4FOX
        • 1675
        Nice build. Curious how these handle vs the daytona hulls.
        • Diesel6401
          Memento Vivere
          • 4204
          Looking awesome buddy. Seems like Ben is really coming up with some excellent hulls. Very cool!
          Sent from my T-Mobile G2 using Tapatalk
          - Diesel's Youtube
          - Diesel's Fleet
          • 08gtrking
            • 91
              • 7673
              Looks like good access for packing batteries in.Nice and open hatch area.I like the slight angle on the sponsons,my MG will trip in a corner on someones wake.
              • tiqueman
                • Jul 2009
                • 5669
                Certainly is a nice hull. If your mg is tripping ... perhaps the cg is too far forward? Mines the only cat that won't trip on traffic wakes. I only hope this hull handles as well as my mg. Unfortunately I've run out of day and steam. I got nothing done on it. Worked outside all day today as its finally cooling off. I may get a bit done tomorrow. I've got some other things to get done for Benjamin as well.
                  • 7673
                  How are the ride pads and edges?I'm gonna start on blueprinting the MG before my hull arrives.And got any ideas on having breakaway on the V-rudder.
                  • tiqueman
                    • Jul 2009
                    • 5669
                    pretty straight, way better than the mg but still not perfect. edges are real clean and crisp
                    • 6BOOST
                      • Sep 2011
                      • 286
                      Haha, looks like Ben is too busy filling orders for people like me every second day to finish his own boat=P Will be intresting to see how it performs compared to his other hulls, I have a HK genesis and one each of his 32 and shocker cat hulls on the way so will be a nice comparison side by side. I see you have his CZ2760 that I tried my best to pry from his possession lol, I'll just have to wait it seems=P At least I'll get to see how it goes first!
                      Make sure you keep us updated after your first spin Ben and great buildup Tiqueman.
                      6BOOST
                      6boost Turbo Manifolds, Australia's number 1 turbo kit specialist and manufacturer
                      • tiqueman
                        • Jul 2009
                        • 5669
                        If all goes well I will be racing it at the local club meet this weekend. My job description is to build it, run it, tune it and review it for him.
                        • 6BOOST
                          • Sep 2011
                          • 286
                          Awesome=)
                          • tiqueman
                            • Jul 2009
                            • 5669
                            I'm hopin so. My goal is actually to have it done fridayish so I can drop it in behind the house and at least get the cog and strut correct, or at least close. Then hopefully Sunday it will be competitive. Its test n tune Sunday, no official racing but it will be going against other q boats.
                            • tiqueman
                              • Jul 2009
                              • 5669
                              Update. Got a couple hours in on it today. Need to figure out where batteries are going to go and install the trays, program the esc, grease the shaft and charge some batteries and its ready to get wet. Im hoping for a maiden tomorrow afternoon. As for the batteries, I may just velcro them to the hull for its maiden until I find the correct position, then install the trays.
                              Benjamin supplied me with a stand up servo mount. I think I saw what his intentions were as a member posted a pic of thier daytona in another post and the servo was mounted down in the right sponson. Although, I think the aluminum ties in better w/ the interior hardware. I used a Dubro quick grip e/z connect at the rudder and swapped out the swivel link on the end of the push rod Ben supplied w/ a Dubro swivel link because the screw I used to connect it to the servo arm would not go thru the ball in the link provided. I installed a Seaking 180 because its what I have. Id imagine the motors going to be able to dish out more prop than the esc can take. But we will see. Ill be starting with a Tenshock 1.6ish x 42mm prop. I believe Benjamin is now carrying these as well. If not, he will have them soon.
                              My only concern for practicality is the motor mount. It truley is a piece of art, but it limits access to the sponsons for battery installation and removal. I really wanted to go 6S2P but Im not sure if Ill be able to get them in. I got 3S packs in it but you have to put them in from the rear and slide them forward. This is easy now with no battery trays, velcro and straps. Once all thats in it may be a bit tricky.
