Got a ELAM hull from a friend which was has some battle scars but should still make a great race boat!
I will be using an aquacraft 60amp ESC & testing the proboat 1500 motor and a UL-1 motor to see which one will give me best speeds and handling.
Going to be using the stock proboat rudder and a UL-1 strut which I will either use stock brass bushing or something recommended??
Ordered a .150 flex shaft and liner from OSE & a Graupner K Series 42mm prop for testing seams people are having good success with x642 prop and not sure what others might work???
I will post up some pictures of it later when I have a chance to take some.
Not sure if using 2 part pour in foam is the way to go or possibly just use some GREAT STUFF anyone had success with using it in this boat??
Figured it might work out ok and add some weight and stiffen things up......
Any advice or help with this will be greatly appreciated!
I have read threw Darrin's race prep and he has some good stuff in there but I am also interested to see what other have done to the boat and had good success with.
