My boat arrived friday in perfect condition with everything i ordered from benjamin at fightercatracing.com
I am very pleased with the boat and hardware. i got a chance to do a little work on it this weekend. Mounted the stingers, rudder and made some rough templates for the bulkead, transom plates and motor mounts. Waiting on the carbon fiber cloth, 1mm and 2mm sheets to arrive this thursday
so i can have everything i need to get underway with the build. Im using the fightercat rudder, stingers, .187 wire drives, cooling blocks, 80hv esc's and bec's. Going to run the boat with Scorpion 3026 1600kv outrunners on 6 cell 5000mah 40c lipos. Purchased some x442's CR and 2 x447's CR.boat 5.jpgboat 1.jpgboat 2.jpgboat 3.jpgboat 4.jpg Going to make sleds for the batteries and an electronics box out of CF as well. This is my first twin build so any suggestions and advice would really help. Thanks again, Charles
So i got start to work this afternoon and got the bulkhead, motor mounts and transom plates cut out. Gotta do some fine tuning and sanding due to the fact that i made the templates before i had the cloth in the hull. Laid cloth for the first time and am pretty happy with the results. took a little time in prep, but was worth it. Still need to finish the sleds and electronics cover but those can wait till everything else is installed. more work tomorrow. thanks
