Darin's Wild Thing 32" P-Mono Build
OK Guys... Got it all assembled... Just have to plug in the RX tomorrow and then do all the final initial adjustments to everything...
With it sitting just like you see it here, it balances at 9.5" from the transom... Just shy of 30%... I can move the packs forward at least an inch, which moves the CG the same amount... One of the nice things about centering the heavy stuff about on the CG!
As long as things don't go up in smoke tomorrow evening on the bench, she'll get wet on Saturday!
Darin E. Jordan - Renton, WA
Just weighed this thing... DANG... 8lbs 13oz RTR (that includes the optional 1500mah NiMH RX 5-cell pack, which is 5oz)....
We'll have to see how the 1521 1.5D does in there at that weight...Darin E. Jordan - Renton, WA
LOT's of sanding and measureing and filling and sanding and measureing and filling and sanding....
I'm not sure how "exact" these are... Because of the way I did them, they were bound to come out about the same size...
I'm not sure how much they come into play while going straight... I DO know that I experimented once on my 26" DH Mono with asymetrical strakes by making one side longer than the other... the boat cornered great, but would NOT drive straight... Cut them even again and everything was fine...
Did I mention to you that it takes a LOT of sanding and measureing and filling and sanding and measureing and fillings and ....
I'd much rather have had a boat with strakes already on it!Darin E. Jordan - Renton, WA
Very well, thanks for asking... I finished out of the points in P-Mono at the Nats, and I don't recall why... I think I flipped one heat... Otherwise, it is PLENTY competitive... I just need to drive better...
In P-Offshore, I finished 3rd overall...
I also set the fastest 2-lap (2-laps on the 1/6th) time of the weekend... But I believe that another day of good weather (no wind) would have seen that time fall further... I know I could have gone much faster with a couple of tweaks and more confidence in the boat...
But hey... it was only it's 3rd time in the water, so overall, I'm incredibly PLEASED!! So much so that I'm going to be selling the 33" Delta Force Hull I have, which is undrilled and already carbon-reinforced, because I like the Wild Thing so much! Mine is fast and handles VERY well...Darin E. Jordan - Renton, WA
