PART 1
Ok, before I start I want to be certain to give credit where credit is due. I received this Fightercat hull partially finished. The stuffing tube, strudder, servo mount, and motor mount, were already installed, and the hull was painted.
This is my first foray away from RTR, so it was a relatively easy step toward moving into the next phase of FE boating. More of a plug n play than a real build, but I did have to install the remaining hardware, and a few minor mods were necessary.
I choose to go with a Turnigy T180 ESC, Leopard 4082 1500kv, and Spektrum MR3000 rx for electronics, and plan to run 6S.
The first challenge I ran into was fitment of the motor. The 50mm long water jacket just fits between the front and rear mounting brackets leaving very little room for front/back adjustment. The water jacket was binding on the hull near the front bracket and I couldn't lower the rear of the motor enough to align it with flex shaft.
Water Jacket Contacting the Hull
I wasn't certain how to correct this. First I thought about putting a 40mm long water jacket on, but I wasn't enthusiastic about reducing the cooling area, the 50mm jacket only covers about 60% of the can as is.
Ben at Fightercat recommended beveling the edge of the water jacket to fit. I was nervous doing this, thinking I was going to grind through the o-ring groove, but I proceeded slow and easy, checking the fit often.
Beveled Edge on Water Jacket
As I continued to increase the width of the bevel it was still binding, so I smeared a bit of paint on the hull to find out exactly where the water jacket was making contact. Turns out that once the jacket was starting to clear the hull, the front end cap of the motor was also starting to make contact.
Both Motor and Water Jacket Contacting Hull
I eventually ended up grinding the entire "collar" area almost flush with the middle section of the can. But still had to solve the problem of the motor contacting the hull.
Water Jacket "Collar" Ground Almost Flush with the Body Section.
I decided it was time to go for broke and applied two layers of fiberglass and resin to the bottom of the hull underneath the motor mount area. I sanded and painted the patch, then used a Dremel cutting tip to carefully etch out a small "belly pan" under the motor mount for more clearance.
Not sure if this is a common solution for this problem or not. Seems obvious this motor mount is intended for 36mm motors.
Fiberglass Patch Applied
"Belly Pan" in Hull Underneath Motor Mount
TO BE CONTINUED
Kevin
